Coolant question
Old Dec 5, 2006 | 09:38 AM
utrico's Avatar
utrico
Default Coolant question
Yesterday my display told me that my coolant was low so I stopped by the store and got some antifreeze. It said it works on ALL models and makes so I was not that worried about it. After I filled up the reservoir I saw that it said it requires special coolant and that you are supposed to mix it 50/50. Do I have anything to worry about just putting in some off the shelf stuff?
Old Dec 5, 2006 | 10:37 AM
INaband's Avatar
INaband
CI 7-8 Veteran
Use the dexcool or similar red stuff...does not have to be 50/50 if you are just topping off...
Old Dec 5, 2006 | 10:41 AM
If it was the green stuff, then that should not have been put in the car. Use only DexCool or a similar product.
Old Dec 5, 2006 | 10:59 AM
utrico's Avatar
utrico
Yeah it was the green stuff... I guess I should flush the whole system now?
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
There's not much you can do about it now. But I am sure you didn't have to put in that much to make a difference. But I would watch the level for awhile. Usually it will only go down if there's a leak somewhere. Look around for leaks if you find one it should be fixed and at that point replace the coolant. If air gets into the system Dexcool has a tendency of globing up. If that's a word? Hopefully you know what I mean. And you should replace the coolant at least every 5 years. My .02
Old Dec 5, 2006 | 11:02 AM
INaband's Avatar
INaband
CI 7-8 Veteran
.........or get a turkey baster and suck all the coolant out of the overflow...if you added more than that, then yeah, I would flush it. Can't mix green and red....
Old Dec 5, 2006 | 12:12 PM
bighank's Avatar
bighank
Default coolant
First go to your PROFILE and at least show what year your C5 is if it is really a C5. Would be more enlightening to give correct responses.
Mine is a 98 and after about 3 years or 36000 miles it is a GOOD IDEA to replace the existing DEXCOOL coolant with new. I took my overflow tank off and spent about 10 minutes flushing it out as well as flushing the entire cooling system with clean clear water. Didn't use any fast flush like I usually do so as not to eat the insides of the vette engine.
Then refill with DEXCOOL at the 50/50 concentration. Cheaper to buy it full strength and add clean water VS buying the premixed (watered down) variety.
Good luck BIGHANK
Old Dec 5, 2006 | 12:22 PM
Jet-Jock's Avatar
Jet-Jock
I think it's DexCool II. And it comes pre-mixed 50/50 for top offs and regular strength for flush and fill.
Old Dec 5, 2006 | 02:22 PM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
I would follow GM's recommendations on this one. I believe they also recommend distilled water, less impurities. Check your water pump, radiator, and hoses. If you keep losing water you have a leak somewhere.
Old Dec 5, 2006 | 02:30 PM
torchredfrc's Avatar
torchredfrc
You should always use distilled water in your 50/50 mix. It is also a LOT cheaper to buy the 100% Dexcool and mix it yourself.
Old Dec 5, 2006 | 02:39 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I always use dexcool mixed 50/50 w/ distilled water available by the gallow from walley world.
Coolant is coolant so you can use the green stuff so long as you do a system flush and swap it.
Dexcool is supposed to last longer.
Old Dec 5, 2006 | 11:25 PM
utrico's Avatar
utrico
Thanks for the info guys. I updated my profile to show that I have a 97. As for the coolant, I had the system flushed and the good stuff put back in. Next time it would probably make sense to read the user manual FIRST...
Old Dec 6, 2006 | 08:28 AM
c3andc5's Avatar
c3andc5
I know too many mechanics that would strongly disagree with that statement. I have been told that under no circumstances should you put anything but Dexcool in an engine that calls for Dexcool. The reason is that other coolant types mixed with Dexcool causes a reaction that very quickly deteriorates gaskets and components. Even small amounts. I know first hand that this is true with my father-in-laws Suburban. He replaced Dexcool with regular coolant and less then 1000 miles later he had coolant leaking everywhere. $900 to fix that little mistake. Bottom line: there is a reason that our manual says to Only Use Dexcool.
Old Dec 6, 2006 | 08:53 AM
Cobra4B's Avatar
Cobra4B
^ Again... I said engine flush... if you flush the system properly you can use regular coolant.
Old Dec 6, 2006 | 09:07 AM
AtiLLa's Avatar
AtiLLa
Here is an article i came across about DexCool. I did not verify its accuracy, but thought it addressed a few topics in this thread....
http://www.imcool.com/articles/antif...l-macs2001.htm
atilla...
Old Dec 6, 2006 | 11:16 AM
Stock Man's Avatar
Stock Man
atilla...
That's a cool site! No pun intended.
Old Dec 11, 2006 | 05:08 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I did the SAME thing about three days ago.
I'
m so used to using tyhe GREEN stuff and always have it on hand.
Anyway the low coolant light came on and I checke dthe coolant.
Sure enough it was just a little low. About 8~12 ounces.
REfilled with GREEN coolant and about time I got it filled up I remembered....... Big UH-OH.
'THey' say you can mix the two HOWEVER I'd rather not.
There are too many horror stories around about Dex-Cool already.
Sooooo... I'm flushing mine and refilling it with Dex-Cool and distilled water.
I KNEW better just forgot.
Old Dec 11, 2006 | 09:41 PM
RonJ's Avatar
RonJ
I saw an anti-freeze, think it was by PRESTONE, the container said it could be mixed safely with green or red. If that's the case, it would make life easier!
RonJ -
To Coolant question
