[Z06] A few Questions
Old Dec 6, 2006 | 01:43 PM
overBlown's Avatar
overBlown
Default A few Questions
Hey guys, i just wanted to run a few things by you to see if they are normal for these cars.
first, when i make very slow turns, 1-5mph, such as pulling out of my driveway, it feels like the tires bind or "pop" much like the way they feel when rolling over a rock. it's hard to explain so i hope some of that makes sense. is it because the tires are so wide up front combined with the camber change when turning the wheels?
the second thing is when it's cold like when its been sitting for a few hours, the shift into second and third feel extra grappy/notchy. it's almost like it's putting up a small amount of resistance but it never grinds. after a few miles and the motor is warm it goes away. is this normal? also the temps here have been in the 20's on average so it's pretty cold. the only reason i find it strange is that my mustang doesn't do it at all when no matter what the temp.
any input would be great. thanks in advance guys!
Old Dec 6, 2006 | 02:03 PM
99vettecoupe's Avatar
99vettecoupe
Yes, the binding is normal. I get in particularly when reversing out of a parking spot when turning sharp in reverse.
Until the oil in the gearbox warms up you will have a little resistance shifting, that's normal too.
Old Dec 6, 2006 | 02:46 PM
overBlown's Avatar
overBlown
hey thanks a lot for the info!! that's what i was hoping to here and i figured it was all normal but just needed to hear it from someone else. thanks again for the help, this site is awesome!!
Old Dec 6, 2006 | 03:16 PM
99vettecoupe
Anytime my midwest brother.
jbauch357's Avatar
jbauch357
the only time I notice the popping in the front end is after the car has been sitting over night, and it goes away after 100 ft or so.
the gear box binding is normal too, you may try replacing the fluid and see if that helps any - did some good for me...
Old Dec 6, 2006 | 04:00 PM
Vetteoholic's Avatar
Vetteoholic
Same here
Old Dec 6, 2006 | 04:15 PM
FrogmanDave's Avatar
FrogmanDave
The shifting hard cold is due to oil temperature as you suspected. Corvette's have very shi**y manual transmissions.
The popping you feel is the limited slip rear end not slipping so well. That's why we add the extra slip additive to our rear ends (at least to the stock non synthetic oil). Nothing to worry about.
Dave
Old Dec 6, 2006 | 06:44 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Shazaam. looks like da'mafia back there behind your Vette.
Old Dec 6, 2006 | 07:42 PM
GARY2004Z06's Avatar
GARY2004Z06
I have had balky shifts into 2nd gear. On the first two passes at the dragstrip on 11/3/06 I could not get it into 2nd. On my third pass I ran a 12.01. Ranger said that I may have overheated the clutch on the first 2 passes.
Old Dec 6, 2006 | 07:55 PM
overBlown's Avatar
overBlown
uuummmm........thanks?
Old Dec 6, 2006 | 11:44 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Overblown -
You are spot on regarding the tire-slip of the front tires.
I have not noticed my trans needing to "warm up".
The Tremec has DexronIII ATF in it, and that stuff does not get thick at normal low temps - it stays pretty thin even when at freezing as compared to conventional gear oils found in many transmissions.
I don't think you have a problem, but as stated above, it is well worth changing out the trans and diff fluids - and it's very easy too.
best regards -
mqqn
Old Dec 9, 2006 | 12:59 PM
Sick Z06's Avatar
Sick Z06
Originally Posted by mqqn
Hi Overblown -
best regards -
mqqn
+1 Could you image the T56 tranny (mn6 or 12) if it had 90w in it?
To the ****ty transmission comment, Are you on something? I can name over 2 dozen worse ones.
Also, its NEVER EVER a bad thing to change the transmission fuild. I would suggest AmsOIL ATF+4. I run it, and it helped quite a bit with the stubborn shifting when cold in my vette, and neon srt-4.
Old Dec 10, 2006 | 01:09 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The viscosity of an ATF and a 90 weight gear oil probably aren't as different as you'd think. The AMSOIL ATF has a viscosity of 37.4 cSt at 40C (100F) and 7.5 cSt at 100C (212F) whereas the Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 has a viscosity of 84.5 cSt at 40C and 14.7 cSt at 100C, about double that of the ATF.
Interestingly, Dodge recommends a 90 weight gear oil for the T56 in the SRT-10 Viper and the above MTG is what AMSOIL recommends for the T56 in the Viper whereas they recommend the above linked ATF for the T56 in the Corvette since that is what GM recommends.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 10, 2006 | 04:35 PM
Sick Z06's Avatar
Sick Z06
Funny you say that. DODGE is the only manufacturer going against what tremec recommends in their tranny. Also AMS is only going by a fluid replacement specification and comparison to the originally recommended fluid type from dodge.
Also do note the syth 75-90 is double the viscosity atleast, over what ATF is.
Old Dec 10, 2006 | 07:42 PM
C66 Racing's Avatar
C66 Racing
That's definitely true. AMSOIL isn't likely to go against the factory recommendation and invalidate the warranty.
To A few Questions
