Touchup 123
Old Dec 6, 2006 | 05:59 PM
vettman96's Avatar
vettman96
Default Touchup 123
Moderators may move this, but anyway. Got info from forum
member. Narrative promised results, which were ok. But mfg.
narrative did NOT say product was a one time use. Went to
web site, communicated with them re/ narrative and suggestions
for rewording to be clear on product. Rep committed to send
replacement product for feedback provided...never happened.
Please understand, the product works pretty much as advertised,
but is one time use only.
Old Dec 6, 2006 | 06:54 PM
Pizzano's Avatar
Pizzano
You can use it whenever you need to refill the spots that were filled originally, there fore its not just a one time use, its actual paint that is used to fill the chips, and can be applied as needed.
Been there done that, my recomendation is not to use the blue paper cloth they give you to wipe the paint filler on with, but to cut a small microfiber towel in pieces and use that for the application process, eliminates any unwanted scratching.
Search the Car Care area, this topic and product has had numerous posts about its results.
Old Dec 9, 2006 | 12:01 PM
vettman96's Avatar
vettman96
Well, I am not sure how you would define one time use, but if
I use the product and the tightly and securly cap the remainder
for use at a later time and then reopen the container and find it
a gelled "goo" that cannot be applied I call that one time use.
Also, the vendor has acknowledged that fact, however, they fail
to mention it in any of the copy they provide. Once exposed
to the atmosphere, it coagulates.
Old Dec 9, 2006 | 02:53 PM
Pizzano's Avatar
Pizzano
Hmmm, I havent had that problem, I used it 3 times allready, what is gooing the paint.
To Touchup 123
