dyno tune?
Old Dec 6, 2006 | 09:14 PM
SeaBass2001's Avatar
SeaBass2001
Default dyno tune?
what is a dyno tune and does it give you any more power???
Old Dec 6, 2006 | 09:15 PM
Mpwr's Avatar
Mpwr
On a stock car you can expect anywhere from 7-10 wrhp more.
Old Dec 6, 2006 | 09:28 PM
RonVette2's Avatar
RonVette2
With some good mods (on my 94 coupe) and the custom tune I gained 29 RWHP
Old Dec 6, 2006 | 09:39 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Went from 356 to 411rwhp with;
Vararam
Long tubes/cats/x-pipe
Stingers
Tune..
(side note: I also have an aluminum flywheel/kevlar clutch which although does not add HP at the motor, it does increase rwhp output slightly by decreasing loss through the drivetrain)
Tune was worth every penny...
Old Dec 6, 2006 | 10:21 PM
A tuner will use a computer or hand-held device to optimize the air/fuel ratio, timing, etc. so you get the best HP the car can deliver based on the car's equipment. You can pick up some good HP by doing the tune if the tuner knows what he is doing. Prices for the tune generally run anywhere from $350 to around $500.
Old Dec 6, 2006 | 10:23 PM
RonVette2's Avatar
RonVette2
Vararam
Stingers
Tune..
NICE #'s and I'd say a good investment too.
Old Dec 6, 2006 | 11:07 PM
Roc87
Guest
Posts: n/a
Not having many mods, I did the tune to eliminate detonation. I was extremely surpised to see the #'s. (BTW, I had a "street" tune, then later went to the dyno)
Old Dec 7, 2006 | 01:08 AM
POK868's Avatar
POK868
thanks for the info I am contemplating getting one myself
Old Dec 7, 2006 | 08:09 AM
Vetteoholic's Avatar
Vetteoholic
On my first tune after the mods I gained over 11 RWHP, but on the re-tune a couple of years later I gained an additional 10.7 RWHP, I had slightly different mods though, but still a nice surprise. If your stock or lightly modded I would go with a Diablo Predator. With mods go with the dyno tune~Well worth It
Old Dec 7, 2006 | 09:07 PM
devnull's Avatar
devnull
Hey thanks man! (pm sent)
Old Dec 7, 2006 | 09:15 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Proper tune is worth every penny
To dyno tune?
