Is it true??
Old Dec 7, 2006 | 05:49 PM
photoguy's Avatar
photoguy
Default Is it true??
I was told that with the flat oil pan on the c5 that you have to tilt the nose down slightly when draining the oil?
True or False??
Old Dec 7, 2006 | 05:51 PM
acerider's Avatar
acerider
yep.
Old Dec 7, 2006 | 06:11 PM
81c3's Avatar
81c3
Its true, & I found it helpful to put a floor jack under one side, raise it up, then do the same on the other. I was surprised at how much oil was sitting in the "wings" even after jacking the rear up a little.
Old Dec 7, 2006 | 06:20 PM
photoguy's Avatar
photoguy
Thanks. I guess if you want it done right...do it yourself!
Old Dec 7, 2006 | 06:31 PM
hotwheels57's Avatar
hotwheels57
Did you read the owners manual? You can also let the air out of your front tires.
To Is it true??
