C6 Z06 Shifter question
Old Dec 7, 2006 | 08:33 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default C6 Z06 Shifter question
My g/f is contemplating buying me a C6 Z06 shifter for christmas, she wound up having to tell me what she was going to get me because she doesnt know how to go about buying it or what all parts are needed and when she called around to the local dealerships they told her it wouldnt fit in the C5. First question I have to ask from those who have put this shifter in their C5 is, was it worth it, is it something that made the car more enjoyable to drive? Will this shifter bolt directly in any year C5, I have an 02 if it makes a difference. Also, which vendor has the best price?
Thanks for any info,
--Chris
Old Dec 7, 2006 | 08:56 PM
mag red vette's Avatar
mag red vette
It made a huge difference. Finding fifth gear with the original shifter was an exercise in frustration. The C6 shifter is smoother and much more accurate. I had A&A Corvette do the install. They also provided the parts. I would highly recommend that you get the Vette Essentials shift boot that is specifically designed for a C5 with the C6 shifter.
Old Dec 7, 2006 | 09:08 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Wait till 12/14 Gene will be back! Order it thru him and save a ton of money!
I have this shifter with the C6Z06 base and its very close to being perfect! I have tried Hurst, B&M and 3 custom home made shifters before finally settling for this.
Its got about 35% shorter throw then normal C6 shifter and cost cheaper than C6 shifter too!
Good luck
Old Dec 7, 2006 | 09:43 PM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
excellent upgrade. much better feel. not perfect but very close.
btw, i have an 02 and like with all the rest it drops right in.
Old Dec 7, 2006 | 09:54 PM
yaknow's Avatar
yaknow
c6zo6 shifter great upgrade you'll absolutely love it. Install very easy takes less than 1/2 hour to install. I bought mine used with 1200 miles on it from a c6 forum member for like $125 shipped.
Old Dec 8, 2006 | 12:40 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Well worth it.
Peace
Chip
__________________
..................Click for
Old Dec 8, 2006 | 12:50 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I love mine. You will need the shifter, **** and **** set screw. Here is a pic of the shifters side by side. The C6 is on the right hand side.
Here's another pic of the shifter in the car. I have since trimmed off the top of the shift boot and zip tied it to the bottom of the C6 ****. It looks much better. Zip tie can not be seen. I need to take a picture of the results.
Old Dec 8, 2006 | 07:14 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I have the C6 shift, and really enjoy it much better than the C5 shift.
Old Dec 8, 2006 | 07:19 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Good luck
Old Dec 8, 2006 | 07:22 PM
zeevette's Avatar
zeevette
I just pulled a BPP, and replaced it with the C6ZO6 shifter, and I'm pleased with the results. A longer throw, but much less notchy. As previously mentioned, you have to get a custom boot, or modify your stocker to fit.
Old Dec 8, 2006 | 07:44 PM
mark896's Avatar
mark896
Do it for sure, and get it from Gene. Don't forget to get the vette essentials boot too.
Mark
Old Dec 8, 2006 | 09:26 PM
Rupert's Avatar
Rupert
I have an '02 like everyone else says a) shifter is smother, b) easy installation (search the archives for install instructions, the hardest part is getting the old **** off of the shifter) c) the **** is much more comfortable in the hand then the squared off stock **** and d) looks cooler then stock ****.
Old Dec 8, 2006 | 10:32 PM
Adrian-S's Avatar
Adrian-S
I bought mine from Gene, it came with the shifter and all the mechanics underneath it. A simple few bolt installation with no worries. Honestly, I can't say the shifting movement feels much different than it did to begin with.
The position of the stick, shorter height, the size of the ****, make a world of difference. That alone makes me happy for the purchase.
Go for it!
-adrian
Old Dec 8, 2006 | 11:20 PM
The shifter's revised angle makes it much more comfortable when shifting IMO. And, it seems to be a smoother shifting piece.
To C6 Z06 Shifter question
