Clutch question
for about a week my clutch has been sticking a bit. Today I went to start it up and I can't get into the gears. Found out it was low on fluid, we filled it and its still stuck, so we jacked it up on the drivers side and then a puddle started forming of clutch fluid. The puddle really started comming while pumping the pedal. Its hard to tell exactly where its comming from
We checked the master cylinder and it looks fine no leaking, but we can't find the slave? Where is the slave? Is it shot?
The slave is buried - you will have to remove the trans to repair it.
It is part of the throwout bearing assembly.
This link has a good picture of a c5 slave/throwout.
http://www.dougrippie.com/drm/drive_...components.htm
best regards -
mqqn
