Cleaning the car....HELP!
Old Dec 10, 2006 | 09:43 AM
travelingypsye's Avatar
travelingypsye
Default Cleaning the car....HELP!
My car is going on display at the National Corvette Museum so it has to be spotless. I need cleaning help. What is the best tar remover for those little tar marks just behind the wheel openings? I have tried several but none work really well. Also what is the best thing to get scuffs off the door sills? I have tried several cleaners including alcohol and vinegar. Thanks for the help.
Old Dec 10, 2006 | 09:49 AM
98IndyPacer's Avatar
98IndyPacer
I use WD-40 to remove tar. Works great!
Old Dec 10, 2006 | 09:54 AM
rws.1's Avatar
rws.1
Stoner's tarminator for the tar..
Those little scuffs on the sills may be scratches in the clear coat.
If they are, hey will need a scratch removing polish and a random orbital buffer. Whcih polish and which pad is impacted by how deep the scuffs are...
Try posting in the car care section on this aspect... a lot of detailing gurus hang out there.
Old Dec 10, 2006 | 09:57 AM
NikiQ's Avatar
NikiQ
Cruise-In 9-10 Veteran
St. Jude Donor '07-'08-'09
Several years ago, I had the misfortune of getting on a country road right after they had tarred the road. My car was thickly covered all along the sides of the car. The advice I was given at the time was to use diesel fuel. With plenty of elbow grease added in, all of it came off.
Old Dec 10, 2006 | 10:11 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Tar's nothing.
Wait until you drive your black vette down a road where they just painted the white lines.
Old Dec 10, 2006 | 10:14 AM
travelingypsye
Originally Posted by JACKAL0PE
Tar's nothing.
OUCH! Thank God that never happened to me.
For the door sills, it's not the paint but the interior molding that is scratched from shoes.
Old Dec 10, 2006 | 10:16 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
One of those Mr. Clean "erasers" will work good on the scuff marks on your door sills. Just do it lightly and they should come right off. As far as the black marks on the fenders, I use 3M Wax and Adhesive remover - as you should be taking the marks off before you wax.
Old Dec 10, 2006 | 10:27 AM
chevyvette1's Avatar
chevyvette1
I have a white Grand Cherokee that was laoded with tar, this stuff worked awsome, once it's sprayed on it would start to, in lack of a better word, start to melt it. this stuff worked better than anything else I've ever tried, you can pick it up at Walmart for like $5 or $6, and of course you will have to re-wax afterwards Ozzie
Old Dec 10, 2006 | 10:30 AM
steve8's Avatar
steve8
I had great luck with wd-40 also, you just need to wash and Zaino afterwards. I also used Mr clean erasers last year and they worked great.
Old Dec 10, 2006 | 10:32 AM
travelingypsye
OF course Zaino! NO car going to the museum should be without Zaino. hehe
Old Dec 10, 2006 | 11:26 AM
yaknow's Avatar
yaknow
I had a lot of tar on my dd, I used those moist orange hand wipes in a tube, can't remember the name brand, worked great! No damage to the paint, minimal effort, and no loss of shop towels.
Old Dec 10, 2006 | 11:38 AM
tellefan's Avatar
tellefan
Grease and wax remover by 3M. They sell it as a prep before painting. It's never hurt my clear coat. Much easier than regular tar remover and WD40.
Old Dec 10, 2006 | 12:11 PM
dwilcox's Avatar
dwilcox
I have used a product called "Bug & Tar Remover" it is made by the Lifter 1 Company - I bought it at Autozone. I unfortunatley have had to use it on our Tahoe repeatedly and on my 01 Coupe 3 times. Just follow the directions, spray it on , let it soak in, and most of the smaller spots will simply wipe off. The thicker/bigger ones amy take a little effort, or a second shot. No damage to the Clearcoat and it is Lemon Scented. I have to admit, I do spot wash and wax the area after every application. Black and Yellow spray can to be specific.
Old Dec 10, 2006 | 06:34 PM
rrichar2591's Avatar
rrichar2591
I had some pretty bad scuff marks when I first bought the car and the Mr Clean erasers were the only thing I could get to take them off. By the way, go the car car section and do a search on any topic your interested in cleaning and detailing the car. There is a lot of good stuff there.
Old Dec 10, 2006 | 07:49 PM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Old Dec 10, 2006 | 07:51 PM
stampede3's Avatar
stampede3
Yep.
Old Dec 11, 2006 | 03:23 PM
I've used WD-40 or just some paste wax to remove tar. The scuff marks may come off with the use of a Magic Eraser.
To Cleaning the car....HELP!
Old Dec 11, 2006 | 03:38 PM
beary58's Avatar
beary58
Peanut butter works great on tar. I know it sounds silly, but I read about it somewhere and tried it. Great stuff, but you need put it on after lunch or you may be tempted to........
Old Dec 11, 2006 | 03:57 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
That sounds crazy. But I believe you.
Old Dec 11, 2006 | 04:24 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
Well let me be the first to say CONGRATS on having your car at the NCM!!!
How long will it be there?
