HELP 01Z will not start!
Old Dec 12, 2006 | 05:36 PM
bmg's Avatar
bmg
Default HELP 01Z will not start!
I turn the key and the car does not turn over. No codes, nothing.
All the dash lights, head lights, etc come on but when I turn the key nothing. No clicking from the starter etc.
Any advice because I am stuck at work!
Thanks!
Old Dec 12, 2006 | 05:37 PM
Z06Aggie's Avatar
Z06Aggie
Got jumper cables?
Just b/c there's enough juice to turn on the lights, doesn't mean there's enough to crank.
Old Dec 12, 2006 | 05:39 PM
bmg's Avatar
bmg
Originally Posted by C5Aggie
Got jumper cables?
Jumper cables didn't do a thing!
Old Dec 12, 2006 | 05:45 PM
LoneStarFRC's Avatar
LoneStarFRC
Push the clutch pedal down when starting?
Old Dec 12, 2006 | 05:50 PM
bmg's Avatar
bmg
Got jumper cables?
Yes, clutch is pushed in.....
Old Dec 12, 2006 | 05:53 PM
Bill Vett's Avatar
Bill Vett
Turn the key on. Look at the DIC is the mileage on the DIC?? If it is the battery could be low. Or a dead cell. How old is the battery?
Old Dec 12, 2006 | 05:54 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Then get a push If I was stuck, and had juice at the dash, I sure as heck would try a push start if possible.
Good luck
Old Dec 12, 2006 | 05:56 PM
bmg's Avatar
bmg
The mileage is showing on the DIC, but I tried jumper cables and still no luck... Battery is about a year old..
LoneStarFRC
With the key turned to the start position and held, push the clutch pedal down until it stops. See if you can hear the relay over on the pass side toeboard click. That relay has to engage in order for power to get to the starter.
Has any aftermarket equipment been added to the car? Any splices, taps, etc in the electrical system?
Check the fuses under the hood too. The big ones.
Old Dec 12, 2006 | 05:57 PM
bmg's Avatar
bmg
Good luck
I may try this soon lol
Old Dec 12, 2006 | 05:58 PM
bmg's Avatar
bmg
Car is electrically bone stock. I do have a CLB installed. I do hear the relay click in the toeboard.
Will check fuses....
Old Dec 12, 2006 | 07:39 PM
bmg's Avatar
bmg
Thanks for the help. I just put a brand new battery in it and that did not do the trick. I pushed the car and popped the clutch and it fired right up. I drove the car home and tried starting the car multiple times and it turns over like nothing ever happened?
I am guessing the starter or starter solenoid is bad?
At least I got the car home
Old Dec 12, 2006 | 07:44 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi bmg -
That is why I suggested to roll the car a little - I have seen starters get a bad spot (for lack of a better description) and when they get stopped in that position, they get stuck -
http://forums.corvetteforum.com/show....php?t=1572119
I have never seen it happen to a C5 yet, but they are getting older now....
Glad you got it home!
best regards -
mqqn
Old Dec 12, 2006 | 08:14 PM
Rans03's Avatar
Rans03
Nice. Glad you got it home.
Post what happened in the Tech section and you should get more opinions/ideas as to the trouble.
Old Dec 12, 2006 | 08:33 PM
LoneStarFRC
Glad you made it home. Don't rule out a problem with the ignition key itself (dirty/damaged) or the lock cylinder needs cleaning. If the key's resistor cannot be read, it may be the problem as well.
To HELP 01Z will not start!
