Hi, i have read on here about people lowering their cars on stock bolts, whatever that means. I was curious on how to do this, and does it effect the drivability of the car. Thanks any info would be appreciated.
There are a few writeups. You will get many opinions on ride quality. Mine is that it will not be impacted as long as you don't push it down too far. If you go too far you should make other changes to accommodate.
Have the car on jacks stands with wheels hanging and leaf spings NOT loaded.
Front Use a 10mm wrench on top bolt going through leaf spring at each end. Turn as if you were loosening the bolt (reverse threaded so you really are tightening) Turn until no gap left between bolt and bushnig.
Rear You'll be working on same bolt that is at each end of the leaf spring. You will need to put an 18mm wrench on the bottom and a 13/16" on the top. Turn until you see only 2 threads showing up top.
I had mine lowered all the way on stock bolts a couple weeks ago. Mine came down pretty far, When it goes in tomorrow for headers I'm going to ask him to raise it back up at least by half. The ride quality over big bumps went completely to heck. It also scrapes pretty bad. The spoiler I consider sacrificial, but not the rocker panels. I try to be careful, come at an angle, yada, yada, but I've had three incidents of pretty good rocker hits. Enough.
It also made the car handle funny and have a lot less traction when accelerating, which I attribute to the need for an alignment. I haven't had that done yet becuase I'm putting on new tires and wheels shortly, plus I wanted to live with the lowering a bit and see about the ride before committing to a particular height.
Bottom line, on my car it looked cool as heck but was not acceptable otherwise. I'm going to try something in between but if I still have trouble it will go back to stock height. The car is too much fun to drive to ruin it for looks. ymmv
Yes... an architect.
You will see ABSOLUTELY no difference in tire wear if the car is used as a weekend driver or for spirited driving. If it's on the highway doing 75 for 5 days a week... then MAYBE.
FACT is... I lowered mine on stock bolts. I waited 6 months to make sure everything was settled. Took it to a Chevy dealer that handles a large volume of Corvettes to check the alignment. He said he hardly needed to make any corrections.
Another fact... after 6 months, there is no uneven wear.
And if an alignment was so imperative after lowering, I think the ((((GM)))) Z06 video that came with my car would've either recommended or mentioned the idea in or around the segment on lowering.
Are you certain of this? I have been putting off lowering mine until I'm ready for new tires, that way can do the tires/alignment thing all at once.
NO. He is NOT certain of this. Not at all. I knew I'd have to get mine aligned but I figured I could wait a couple of months before it was a problem. Next thing I knew, I was in the tire store buying a new set of tires AND an alignment.
That may well have been your experience; I'm not doubting you. On my car the handling difference was so dramatic that it is clear it needs an alignment, and badly. I don't think it is safe to conclude that all cars will respond the same way yours did.
