[Z06] Active Handling saved my butt!
Well, after the water hazard, the azzhole in front of me decides to slow down before entering the freeway. So, while still in the sweeper, but well past the watering hole, I move in the right lane to go inside of him before the ramp narrows down to one lane. Just as I complete the lane change, the Z decides it wants to keep turning right. I was literally pointed about 30 degrees to starboard. No doubt the weinie I was passing had a spectacular view of things.
Rather than get crazy with the wheel, I just kept the wheels pointed in the direction I wanted to go, kept on the throttle slightly and swore a mighty "oh $hit!!". Lo n'behold, the car gradually came around to straight ahead, I hit the gas and all was good.
Phew! Not the first time AH has helped me out, but certainly the most potentially disastrous circumstance had it been switched off. Of course, I never had time to look down at the display to see if it had actually engaged, but I assume it wasn't MY driving that saved the day. In any event, thank you GM!!!
Glad that worked out for you.
Figure 1 - VERY tight decreasing radius loop.
Average passenger car will drift at 30 MPH. Z06 capable of multiple that.
Nice pic there Twilight, but I don't see your car.
Maybe you saw the picture of the Viper on PCH in Newport this weekend. It took me quite a while to figure out that it was a Viper. They said the road might have been wet. The driver will never be able to tell us what happened.
Oh yes, Vipers don't have Active Handling.
Be pretty sick if you could time that...
If you see "warming up" a lot, maybe look into getting your PCM diagnosed and/or AHS sensors looked at. Got any codes in the 'puter?
I love it. Than you.
This one save, the system probably saved you 10s of thousands of dollars in repairs, time, and possibly injuries or worse.
I swear by the system. It has saved my but in slippery conditions as well.
Im very happy to see you came out of this OK.
Congrats!!
That's normal. It's cycling the system components to get heat in the fluid and pads and take readings so it can do what it does.
You just can't stop can you. I've said the same thing about AH since day one. Works great. If you're a professional racer and you're driving it on the limit you will not enjoy it. I've talked with several other professional racers at various events (including ALMS this past summer) who state the same thing and describe the same reasons which is why they don't run it even when it's pouring down rain - I don't expect you to get it, you're not one, and you've consistently demonstrated that you lack the basic logic to understand there are people that can do things that you cannot. I know my limitations - you wouldn't see me trying out for an NFL team, not one of my skills. The average person driving this car isn't/wasn't a professional racer, and therefore it's a fantastic system to be placed in the car - and comes with an off switch where applicable. That's pretty much what I've said consistently since the first time I posted in an AH thread. Know your limitations Purvis - you haven't been where I have and I wasn't there by chance. How's that grab you?
EDIT: On a side note, I dug this up:
http://www.corvetteracing.com/cars/c...is_specs.shtml
http://railpax.railfan.net/NAIAS2005/C6R-Switches.jpg
The C6R doesn't even have ABS on it. They actually expect a race driver to be capable of braking to the threshold of impending lockup all by himself! The nerve of those engineers to not give Ron Fellows active handling and abs brakes.
Heck, Ron Fellows got plenty of nerve all by himself.
He don't need no stinking AH and ABS.
BUT I DO!!!
That must've been quite a wipeout on PCH so as not to hardly even recognize the car. The power these things produce HAS to breed respect for the vehicle, and GM did us right by incorporating a sophisticated system for keeping the shiny parts shiny, and the occupants intact.
I can't believe I didn't lose it the other night...
