Amsoil 10W-30 Oil Sample Results!
#41
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have a question. With the new oils performing better and apparently staying cleaner, where does the dirt go? If it goes more into the filter and as that gets dirtier, does at some point it get harder to allow the oil to pass through? Anyone ever tested that? I am all for not changing oil as frequently, but I am at a loss to really understand where the dirt goes and what the impact of the other compenents may be.
#42
![](/forums/images/ranks/7k-10k.gif)
#43
Dogface
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
St. Jude Donor '15, '17
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Great post Ike,
I use Amsoil 10-30 also. I am at 5k now and the DIC says 42%. I am shooting for 8K on this change and will send the sample in to Blackstone at the next change. Did you use an Amsoil filter? By the way my 02 Z has 52,000 miles on it. I hope it's finally broken in
Take care, Don
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
Take care, Don
#45
Great post Ike,
Take care, Don
Take care, Don
Same here..I follow the DIC too but the winter months came up sooner!
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Post up the results for 8k miles!
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
#46
Premium Supporting Vendor
That's a good point. A filter will fill up with dirt and restrict oil flow through it. Depending on the construction of the motor and/or the filter, you might not see this as either the motor or the filter may have a bypass on it to protect against this situation. If your filter gets "full" and goes into bypass, it certainly isn't filtering much for you.
Most filters on the market are probably safe for use per the DIC or GM would require a more stringent filter change interval.
For those who go longer than OEM recommendations, the AMSOIL Ea Oil Filter is a good choice as it is rated for up to 25,000 miles or 1 year of use in normal service.
Another large factor in the amount of dirt in your oil is the air filter. You can really see the effects of a dirty air filter in used oil analysis reports.
In Ike's case, his air and oil filters are doing well overall as silicon (which is what dirt will shop up as) is only 7 ppm vs the labs universal average of 22 ppm.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
__________________
![](http://www.c66racing.com/images/Banner-450x60-C66-Racing.jpg)
![](https://www.corvetteforum.com/forums/signaturepics/sigpic23956_1.gif)
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
#47
#48
In Ike's case, his air and oil filters are doing well overall as silicon (which is what dirt will shop up as) is only 7 ppm vs the labs universal average of 22 ppm.![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
#49
This is another reason why oil analysis is important. A lot of people have done oil analysis and found out that they were getting too much dirt into their oil, and traced the problem back to the air filter (or induction system in general) and were then able to correct this problem and significantly improve their engine wear. So even if you just do one single oil analysis, it could save your engine if you are able to correct a filtration problem like this.
#51
That link is to another AMSOIL Dealer's website. I've got similar data, plus samples from Vette owners such as Ikester's on this page of my dealer website:
AMSOIL Performance Tests
