Just fixed the headlight again!
Old Dec 15, 2006 | 08:16 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Default Just fixed the headlight again!
Well, apparently Rodney's glue desn't work that well.
I'm refering to the kit for changing out the gears in our headlight motors.
The gears are great, however the epoxy leaves a lot to be desired.
I had installed the brass gears a while back and used the epoxy included. It separated and the glue flakes fell off, even though I had cleaned all the surfaces with alcohol first before I glued it.
Sooooo....This time I got smart, after I reglued it I took my trusty old soldering gun and melted the entire edge of the cap where it joins the gear case.
It's definitely solid now!
Just a helpful hint if yours pops open!
Old Dec 15, 2006 | 08:18 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Dec 15, 2006 | 10:48 PM
RDVT4ME's Avatar
RDVT4ME
Rodney has fixed that problem. His new kit has different epoxy and also an additional brace that is used. I had the same problem as you, contacted Rodney and he sent the updated kit in a very timely fashion.
Old Dec 16, 2006 | 12:01 AM
JC in XTC5's Avatar
JC in XTC5
The Brace! That's what will keep it from separating.
Old Dec 16, 2006 | 01:56 AM
RatedX's Avatar
RatedX
I was scratching my head trying to invent just such a brace when I got disgusted and melted the thing!
Old Dec 16, 2006 | 02:28 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i drilled several small holes thru the cap and the housing. i then inserted some cotter pins and twist tied them and clipped off the excess.
it's definately on there solid and the pins can be clipped if i ever need to go back in there again.
To Just fixed the headlight again!
