inner door panel
Old Dec 16, 2006 | 04:17 PM
adf's Avatar
adf
Default inner door panel
hello out there. I am wondering if someone would be kind enough to tell me if the lower portion of my door panel on my 99 vette can be removed separately or is the panel one entire assembly from top to bottom? I want to install red leather on the door panel, however, just the piece on the bottom.
Thanks,
Dean
Old Dec 16, 2006 | 04:30 PM
double-oh-coupe's Avatar
double-oh-coupe
I've seen a post about this ... I believe you have to drill out a couple rivets (or little melted plastic ******* maybe, then riviet back together)? Seems I remember Willfulone did this to his lower door panels -- might search againt his user name and see what you find. If it's not him, I know someone has done it, and they'll chime in! Good luck!
Old Dec 16, 2006 | 04:36 PM
double-oh-coupe
Found it -- Willfulone was the one.
http://forums.corvetteforum.com/show...ght=door+panel
Old Dec 16, 2006 | 04:37 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
It is one complete panel. This link to the instructions from Vette Essentials showing how to remove it might help...
http://www.vetteessentials.com/instr...or_handle.html
Old Dec 17, 2006 | 09:02 AM
adf's Avatar
adf
Default door panels
Originally Posted by double-oh-coupe
Found it -- Willfulone was the one.thanks for the reply, very helpful.
Dean
thanks for the reply it is very helpful.
Dean
Old Dec 17, 2006 | 09:04 AM
adf's Avatar
adf
Default kick panel
Thank you very much. This tells it all. Appreciate your assistance.
Dean
To inner door panel
