Dash glare?
Old Dec 16, 2006 | 09:00 PM
OsoBear's Avatar
OsoBear
Default Dash glare?
Driving into the sun today, got lots of glare from top of dash, (maybe the previous owner was overzealous with the Armorall). Anyhow I'm looking for suggestions to dull the top, without damaging anything. Ideas?
Old Dec 16, 2006 | 09:02 PM
C5naples's Avatar
C5naples
Do a search in the car care section, they were recently talking about that same subject. Someone knew how to remove the gloss .
Old Dec 16, 2006 | 11:30 PM
jrose7004's Avatar
jrose7004
Use dish soap and a sponge and wash the Armorall off.
Old Dec 17, 2006 | 07:51 AM
Take some very mild dishwashing soap (like Dove or Ivory) and put in some warm water. Then moisten a washcloth with the soap and water and gently wipe down the dash. Follow up with a washcloth in clean water with no soap. Then towel down if needed. I've done this to my dash to clean it and it works very well.
Old Dec 17, 2006 | 07:55 AM
randy814u's Avatar
randy814u
I bought a nice dash mat. It looks nice, and keeps the dash in good condition. In the winter I take it off, and in the summer I put it on.
Old Dec 17, 2006 | 08:13 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I agree, the glare from the dash on my Z06 makes seeing very difficult. I've thought about buying a dash pad for mine as well. I've tried cleaning everything off the dash but it's still pretty tough to see clearly...
Polarized glasses work the best....
Old Dec 17, 2006 | 09:58 AM
Jet-Jock's Avatar
Jet-Jock
When you wash your Vette, most likely you'll have some soapy water left over (I usually have a quarter bucket), wet and wring out a rag, and wipe down all the plastic surfaces such as the dash pad and garnish moldings, door panels etc. This will keep them looking new, and should remove any surface applications applied by a previous owner. It may take a few times to get it back to it's original look. (see owner's manual recommended procedure for cleaning interior)
Old Dec 17, 2006 | 10:05 AM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
I had the exact same problem. I used Griot's Garage Interior Cleaner on a terry cloth towel. Worked like magic. It's less than 10 bucks and I could not be happier. The dealer COATED my dash in Armor All and I was sick of getting that crap on my hands and the wheel and the shifter, etc.
Old Dec 17, 2006 | 10:14 AM
vettman96's Avatar
vettman96
I had the same problem, a dashmat solved it.
Old Dec 17, 2006 | 10:49 AM
rwsr50's Avatar
rwsr50
I think the biggest contributor to this phenomenum is the sharp angle between the windshield and the dash. It definitely is a problem.
Old Dec 17, 2006 | 11:58 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Polarized Sunglasses and 303 Protectant...........
Old Dec 17, 2006 | 11:59 AM
MolarMan's Avatar
MolarMan
I know this may not be a full solution to the problem, but have you tried polarized sunglases? I have them and they cut glare substantially. Its not a 100% fix, but at least i can see. Just a different idea. Hope this helps.
Andy
Old Dec 17, 2006 | 12:07 PM
fixvet's Avatar
fixvet
Old Dec 17, 2006 | 12:08 PM
OrangeVegaGT's Avatar
OrangeVegaGT
The polarized glasses work well and if you need perscription lenses walmart sells clip-ons that work also. It is really bad with the shale interiors on AE and CE models. The polarized lenses will cut way down on the brightness of the HUD, but it is still readable.
Old Dec 17, 2006 | 11:28 PM
87SAM's Avatar
87SAM
I use a dash mat on occasion, and even then, when conditions are right, there is still the reflection.
Old Dec 17, 2006 | 11:38 PM
ALLEGRO's Avatar
ALLEGRO
Polorized glasses will make your HUD impossible to see.......
Old Dec 18, 2006 | 05:47 PM
darb21's Avatar
darb21
I don't believe this statement is true. I drive mine with a polarized set of clip ons for my prescription glasses and I see the HUD just fine. In fact, the very first time I drove it during the day I couldn't see a darn thing until I put the polarized clip ons on my glasses...
Old Dec 19, 2006 | 08:28 PM
rrichar2591's Avatar
rrichar2591
Not only does it cut down the glare but protects the dash in direct sunlight. I remove it for car shows etc otherwise, I leave it on all the time.
To Dash glare?
