help on steering wheel removal
Old Dec 17, 2006 | 08:30 AM
kww's Avatar
kww
Default help on steering wheel removal
Any suggestions on the removal of a steering wheel. I've used the proper 3 prong tool and it just won't budge. Have tried to soak it overnight with product for frozen bolts and no luck-it won't budge. Short of using a breaker bar any suggestions that won't crack the wheel ($275 core charge) or another tool. Thanks.
Old Dec 17, 2006 | 09:00 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Have you posted this in the tech forum? Bet you'll get a fairly quick answer over there.
Old Dec 17, 2006 | 09:29 AM
Hrdtop00's Avatar
Hrdtop00
I had the same problem when removing my steering wheel to install a VE wheel. Ended up taking my car to a local GM tech. He pulled the old wheel & installed the new wheel for $35.00. He said that my steering wheel was one of the hardest he's had to remove.
Old Dec 17, 2006 | 09:54 AM
kww's Avatar
kww
Thanks-I'll try both.
Ken
Old Dec 17, 2006 | 11:39 AM
garypz53's Avatar
garypz53
When I took mine off, I used the puller to put a good deal of tension on it but it would not break free. While under this tension, I used another mallet to shock the column and eventually it popped off.
Old Dec 17, 2006 | 11:46 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
__________________
..................Click for
Old Dec 17, 2006 | 05:42 PM
kww's Avatar
kww
Thanks guys appreciate the help.
Ken
Old Dec 17, 2006 | 06:04 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Snap on truck or Napa
KD part #3510 J hook pullers
you need the specific tool
yes, some wheels are really difficult to remove
To help on steering wheel removal
