stall converter question
Old Dec 18, 2006 | 09:02 PM
1radvet's Avatar
1radvet
Default stall converter question
I just installes a Yanks 2800 stall converter
i really can not tell a difference
how do i know if the converter was ever installed
I also changed out my gears to 3:73's at te same time
I have a 2001 A-4
How do i work the stall
Help Thanks
Old Dec 18, 2006 | 09:16 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
I dont know what gears you had before the 3:73's? But if you had the 2:73's or 3:15's if your car is a A4, you should see a very big diff out of the hole!
Chas
Old Dec 18, 2006 | 09:25 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
How to work the stall... from a standstill or a roll - stand on the gas...
and them buy some new rear tyres because they should be a big cloud of smoke
Old Dec 18, 2006 | 09:42 PM
istsme98's Avatar
istsme98
Old Dec 19, 2006 | 01:35 PM
1radvet's Avatar
1radvet
Ok, stand on the gas!!!! well it smoked the tires before the gears and stall
Is a 2800 stall enought to see a didfference from the factory
Old Dec 19, 2006 | 02:11 PM
LMB-Z's Avatar
LMB-Z
Your post said you installed the converter, then asked the question if it was installed. I am confused.
Old Dec 19, 2006 | 02:17 PM
ljoseph's Avatar
ljoseph
Default Stall
With your foot on the brake, the tranny in gear, and the throttle wide open the motor should rev to about 2800 rpm. Take your foot off the brake and away you go, after the tires stop smoking that is.
Old Dec 19, 2006 | 02:40 PM
Ruz's Avatar
Ruz
He paid to have one installed, but not sure if the work was actually done.
Old Dec 19, 2006 | 03:03 PM
Logansar's Avatar
Logansar
Chas
That very mod is high on my list... the converter and going from 2.7s to 3.7s... I was hoping that there would be night and day difference ...
Sgt Paul
To stall converter question
