MBA shift knob questions
Old Dec 18, 2006 | 09:53 PM
gja's Avatar
gja
Default MBA shift **** questions
So my shift **** came in today and I cant figure out two things:
1) What are the plastic circles for?
2) How do I screw the shift **** on tight AND get the emblem to be right side up?
Old Dec 19, 2006 | 11:24 AM
hotwheels57's Avatar
hotwheels57
Didn't the **** come with a jamb nut? It's probably 9/16-18 thread pitch which you might be able to find in a well stocked hardware store.
Maybe the plastic discs are used as spacers to clock the **** in the desired position?
I have a black HURST six speed **** on my oem shifter. It came with a jamb nut, but I wanted to lower the **** as far as possible. I placed a buttonhead 1/4-20 screw (as a shim) in the machined slot at the top. This took a little experimentation to find just the right "shim". It allowed me to screw the **** down tightly, clocking the pattern perfectly. I also used a light application of blue LOCTITE.
