Oil Change
Old Dec 19, 2006 | 02:55 PM
98blackonblack's Avatar
98blackonblack
Default Oil Change
Just had my oil changed at a local shop here, and when I picked the car up they told me that the power steering was seaping and that the rear main seal was also leaking a little is this common i have nearly 80,000 mile on the car...
Old Dec 19, 2006 | 03:00 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
The rear end leak is very common in the C5. Search around here for a bunch of threads about it.
Old Dec 19, 2006 | 03:30 PM
98blackonblack
Is it something to worry about?
Old Dec 19, 2006 | 03:38 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Yes, over time enough can leak out that it will be a problem.
Old Dec 19, 2006 | 03:39 PM
jrose7004's Avatar
jrose7004
I'd want a leak fixed!
Old Dec 19, 2006 | 03:58 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Did they indicate how bad it was, and how much fluid was lost? Any leak needs immediate repair. The rear end leak fix is pricey, but absolutely necessary. A good Vette mechanic will know exactly how to fix it since it's a fairly common problem.
Old Dec 19, 2006 | 04:09 PM
98blackonblack
Said it wasn't something to worry about right away as it was a seepage more then a leak.....
Old Dec 19, 2006 | 04:57 PM
mike348's Avatar
mike348
Nothing to worry about. If it doesn't leave drips its OK.
Old Dec 19, 2006 | 06:48 PM
Any leak will only get worse, but if it is just seepage, you probably have some time before you really need to get it repaired. . I think he is talking about the rear seal on the engine, not the rear differential seal leak.
To Oil Change
