Shifters, down to two choices...Help
Old Dec 21, 2006 | 11:54 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Default Shifters, down to two choices...Help
I'm new to the Corvette, and the shifter product choices. Let me describe what I want, and pehaps of the two choices which will fit the bill. Okay, I want the shifter short and precise and I want SLIGHT effort
1-2 and 5-6. I find the stocker long and difficult to pull into 6th speed, I've got to keep an uncomfortable amount of pressure to the right not to screw up sixth and go into 4th.
I'm thinking of the B&M Ripper, #45044, or the Breathless performance unit.
I'm probably going to use a classic Hurst **** 1 3/4" in black. (I also like the new c-6 Z06 ****, but it's pricey) Any advice,
John
Old Dec 21, 2006 | 12:09 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Looks like you have already eliminated the Hurst... if not, you need to. I like mine a lot, but it is the opposite of 'light effort'. I think you'll find most of the after market shifters have a pretty firm feel (high effort) because of the leverage you lose with the shorter 'lever'. I've tried an older model of the B&M and it had an easier throw than my Hurst, but was still pretty firm.
A lot of people have reported very good results with the C6Z shifter. You might search for some posts on it. I believe it's a shorter throw, but still pretty light. Many good reports on the Breathless unit as well...
Old Dec 21, 2006 | 03:34 PM
weisser's Avatar
weisser
I don't think you'll find an aftermarket short throw shifter that requires less effort than the stock unit. I went with the c6z shifter for the shorter height and much improved ****. Shifting effort is close to stock but feel and lever position is greatly improved. Good luck with your choice.
Old Dec 21, 2006 | 03:35 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have tried them all including some home made shortened ones. I finally settled with the C6 Z shifter. Best IMHO
Old Dec 21, 2006 | 03:37 PM
Honez's Avatar
Honez
I have a Breathless shifter if you want it I will sell it for $100. Just PM me. By the way if you want slight effort then stay with your stock unit. None of the aftermarket shifters are easier. They are shorter, stiffer and more precise.
Old Dec 21, 2006 | 06:25 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
I'm with TripleBlackxTwo. Yah, dat's right! I LOVE my Hurst, but it's a very RACY (read: so stiff it requires manly arms to shift) feel. I vote for the C6 shifter for shorter yet still girly man feel...
Old Dec 21, 2006 | 07:31 PM
c5frc's Avatar
c5frc
IMO: I would go with the B&M Ripper...just make sure the **** you get fits before spending your money on it.
Old Dec 21, 2006 | 08:14 PM
photoguy's Avatar
photoguy
Old Dec 21, 2006 | 08:52 PM
Ohiostatefan's Avatar
Ohiostatefan
C6Z
Old Dec 21, 2006 | 09:19 PM
Mpwr's Avatar
Mpwr
I have a B&M ripper with C6 **** and its sooooo much better than stock...but its very stiff. I personally like it better this way
Good luck
Dan
Old Dec 21, 2006 | 09:23 PM
Bill Dearborn's Avatar
Bill Dearborn
John
If you are looking for slight effort on the 1-2 and 5-6 shifts then you need to stay with a stock shifter. All the aftermarket units are going to increase that effort since they add springs to increase the centering force toward the 3-4 gate. Shortened shifters will also have increased force since the leverage is reduced.
If you are having trouble getting from 5 to 6 it may be more a function of how you are holding the shifter than the shifter itself.
Bill
Old Dec 21, 2006 | 09:29 PM
Over-Rev's Avatar
Over-Rev
have been tinkering with my hurst for a few weeks now. finally think i found the best spring combo (just the single large stiff springs without the smaller secondary springs in the center, with the springs tightened down 3 full turns). this with my rod shortened about 1/2 inch.
i have the hurst black shift **** and the anti-venom mod and mobil 1 trans fluid. think i finnaly found a winning combo. its stiffer than stock but not too stiff and it still has a tight feel to it.
try messing around with settings on other shifters, you may find one is better than the other initially but it may not be as good after adjustment.
Old Dec 21, 2006 | 09:44 PM
Ron C!'s Avatar
Ron C!
I have had a Ripper in my car for a month or so. Throw is much shorter, however effort grows as the throw shortens. Very precise, just a click-click in your are in the next gear. At first, it kept feeling like it was not in gear as compared to the stocker I was accustomed to. Took a few weeks to get accustomed to the added effort. I even had thoughts of pulling it and trying something else. At this point I really like it and have gotten used to the higher effort required, really don't notice it anymore.
Old Dec 21, 2006 | 09:49 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I have a B&M Ripper and I wouldn't have it any other way. It's very stiff, but very precise.
Old Dec 21, 2006 | 10:03 PM
diyguy's Avatar
diyguy
Put my Hurst a year ago. I've tried many settings and I know what you are talking about from the 5-6 instead of 5-4. It's more of a technique that is learned that makes for a smooth seemless no brain 5-6. Still takes some outward pressure to assure 6th, but you can easily 'feel' if it isn't right ahead of time.
That said, I still LOVE the shorty over ANY stock (c5) shifter. Very precise, narrow gates and no problems on hard powershifts. Solid as a rock.
When I drive a a C5 (or Z06) stock shifter now, it feels more like a John Deere tractor. ANYthing would beat that after using a shorty.
Good luck in your decision.
Old Dec 22, 2006 | 10:13 PM
C5 Z16's Avatar
C5 Z16
Default Shifters
I had a Hurst changed it out for a B&M Precision Shifter. It has a rubber isolated shaft. The Hurst rattled this one does not.
Old Dec 22, 2006 | 10:49 PM
jbauch357's Avatar
jbauch357
If you want to substiantially shorten throw, add precision, and add a little extra force perform the anti-venom mod and install your short shifter.
My final magical combination was: MTI 6-shooter, anti-venom, AmsOil ATF, dynomat all around and on the shifter, F-body shift ****, and many attempts at adjusting the shift box assembly.
Realistically it all comes down to each persons preference, but it feels perfect to me now - and my main complaint about the car was how it shifted...
Old Dec 23, 2006 | 07:59 AM
Black 'n Tan
St. Jude Donor '07
Thanks for the info, I've ordered a B&M ripper which I'll use with a stock C-6 ****. I'm no stranger to after-market shifters, as I have a Steeda Tri-ax in my Mustang. My wife and I both have GT's, she an '01 Bullitt, and I, a highly modified '04 GT. My wife's Bullitt is up for sale and is all stock. Just this week, she tried my GT, which she is taking over as her replacement. With it's short throw shifter, SHE WAS AMAZED at how easy it shifted, she raved about it. She noticed how vague the shifter in the 'vette is, and is reluctant to try the car until I get a short throw in. I can tell already the 'vette will take more effort to shift with it's bigger gears, would redline ATF in the box help? Despite the shift effort, I dislike the looseness and long handles of stock shifters, my fear with a stock Z06 shifter would be that it would be only mildly better than the stocker, so ripper, here I come.
Thanks for your help,
John
To Shifters, down to two choices...Help
