Brake Rotor Replacement
Old Dec 21, 2006 | 05:46 PM
CC Rider's Avatar
CC Rider
Default Brake Rotor Replacement
My 2004 Coupe will need new pads and rotors eventually. I plan to get slotted/cross-drilled rotors and ceramic pads. I read in the Corvette shop manual that the rotors should be matchmarked to the original postion on the hub before removal. The manual does not explain further. My question is: Matchmarked where on the hub? Has anyone done this surgery on their Vette? Thanks in advance for any good advice!
Old Dec 21, 2006 | 07:18 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
I just replaced my factory rotors with the GM cross-drilled and slotted rotors and didn't do what you are talking about. I just took the caliper off and moved it out of the way (leave the brake line attached), removed the caliper bracket, pull the rotor off, put the new one on, put the caliper bracket back on, torque the bolts to spec, put the caliper back on with new pads, torque the caliper bolts to spec, bled the brakes and that was it. It took about 3 hours but I think I could do it much faster now. Hope this helps you out. Good luck.
Old Dec 21, 2006 | 07:33 PM
rickko's Avatar
rickko
Don't know anything about what you are asking but I do have a web site showing steps to remove and install rotor's:
http://dana60.com/rickko/corvette/rotor-rr.html
Good luck!
Old Dec 21, 2006 | 10:10 PM
TEXHAWK0's Avatar
TEXHAWK0
I have seen that in my service manual also. They are matched with the hub to eliminate rotor run-out, but I have never known anyone to have any problem with run-out when installing new rotors.
Old Dec 21, 2006 | 10:45 PM
That's what the dealer did to mine when they installed my aftermarket rotors. Simple swap out was all they did and no problems.
Old Dec 21, 2006 | 10:48 PM
JWB ZO6's Avatar
JWB ZO6
with new rotors not necessary
Old Dec 22, 2006 | 12:28 AM
50th in the 49th's Avatar
50th in the 49th
I believe that is only if you are putting the previous rotors (the used ones) back on the car so they are matched to their previous position in relation to the hub. Isn't applicable if you are putting new rotors on.
Old Dec 22, 2006 | 09:55 AM
CC Rider's Avatar
CC Rider
Good luck!
Rikko: Great article and photos! What you describe is percisely what I intend to do! I have about a week off and intend to paint my calipers. When time comes to replace pads and rotors I intend to paint the brackets. Thanks again, and keep smoking those Mustangs!
Old Dec 22, 2006 | 10:13 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
maybe so, but I change my rotors all the time from Track back to street and never mark either set. I never had a problem.
To Brake Rotor Replacement
