[Z06] Column lock related problem??
Old Dec 22, 2006 | 12:46 AM
chargedsol's Avatar
chargedsol
Default Column lock related problem??
hey guys:
i just got the dreaded service column lock message yesterday morning while starting my car. I had it towed to Courtesy Chevrolet where they performed the recall on it.
the problem is that now..my keys feels a bit stuck when i put it in the ignition and turn, also the hole that my key goes into doesn't seem to be aligned correctly. do you think that this is a easy fix? After what happened this time i'm not too eager to take my z06 back in to fix the problem.
Old Dec 22, 2006 | 02:21 AM
mark896's Avatar
mark896
First off, I wouldn't of had the recall done at all. I would've made the stealership unlock it, and installed the column lock bypass and be done with it. The recall has proven itself time and time again, to do more harm than good.
See if you can get it taken off and order a column lock bypass module from corvettes of houston or thunder racing immediately!
Mark
Old Dec 22, 2006 | 08:48 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Why would the dealer be fooling with your ignition switch? That's not part of the recall, unless they found another problem.
Old Dec 22, 2006 | 10:34 AM
chargedsol's Avatar
chargedsol
thats what i thought..the dealer should only have had to remove the driver knee bolster to access the steering column right??
so its confusing to me why the ignition was affected. any other ideas?
Old Dec 22, 2006 | 11:21 AM
mark896's Avatar
mark896
When one of the recalls is performed, and I'm not sure which one you've had done, they take the locking plate out of the steering column so that it physically can't lock up. To do this, I'm sure they had your console apart. Maybe they screwed something up while diggin around in it?
To Column lock related problem??
