[Z06] Cam Only Questions
Old Dec 23, 2006 | 09:23 AM
Covert 405's Avatar
Covert 405
Default Cam Only Questions
I'm currently looking for a cam for my '03 Z06. I'm looking for a cam with a noticable lope, yet nothing extreme. I want it be streatable but with a cam that makes people look twice. Also, I don't want to mess with valve springs, heads, pushrods, etc. I just bought a house I'm fixing up so I'm rather tight on funding! (Lowes is seeing most of my loot right now).
Current engine mod:
Breathless Vortex CAI
BB Bullets
Others:
Short-throw
CAGS Delete
Before the cam went in, I'd probably also add a power duct. I wouldn't tune untill all the new toys were installed.
Anyhow, any advice on a cam that meets these needs (MS3, LG cam) is greatly appreciated.
Thanks and happy holidays!
Old Dec 23, 2006 | 09:32 AM
kylew5's Avatar
kylew5
6th Gear
subscribing
Old Dec 23, 2006 | 09:33 AM
97 SC Cobra's Avatar
97 SC Cobra
The cams you have listed will definately need a spring upgrade and probably a slightly longer pushrod. If you didn't want to go extreme I would choose a TR224 (Thunder Racing). Lot of guys on Ls1Tech swear by this little cam. You could probably get away with some 918 springs with the 224 and hardened PR's are always a good idea. They're $100 new but you can find them floating around for cheap.
PR's for sale (These might not be the length you need/Your vendor will set you up though)
http://forums.corvetteforum.com/show...light=pushrods
BTW, you will need tuning with any cam for it to perform to it's potential. Allow around $400-500 for this unless you have a friend who can hook you up.
A budget cam set-up is probably going to run you $1k if you install yourself.
Old Dec 23, 2006 | 11:13 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Old Dec 23, 2006 | 12:36 PM
White99FRC's Avatar
White99FRC
i have the TR224/Comp 918/Hardened Pushrods setup and I love it. Idles smooth and you very nice gains throughout the powerband. Check my sig for numbers and 1/4 mile times with this cam and mods on my 01 Z06.
Old Dec 23, 2006 | 10:59 PM
Hypex's Avatar
Hypex
so you want a big cam with no headers?
Old Dec 23, 2006 | 11:59 PM
Covert 405's Avatar
Covert 405
Streetable cam, no headers. Thanks for the helpful input everyone else.
Old Dec 24, 2006 | 12:34 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Don't waste your money... save up and do the cam and long tubes at the same time.
Any aftermarket cam needs valve springs.
To Cam Only Questions
