Wheel Bearing question?
Old Dec 24, 2006 | 10:51 AM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Default Wheel Bearing question?
Well, I believe I have a bad wheel bearing in the front passenger wheel. I was making a left turn the other day and heard something give up in the front end. I immediately pulled over and started checking everything underneath the car and under the hood. After not seeing anything wrong, I started to think that maybe I had run over something so I decided to keep going. As soon as the car started moving I started hearing something in the front wheel. My guess is a wheel bearing.
My question is this, has anybody changed this on their car before and if so do you have any diagrams. Not being very mechanically inclined I need all the help I can get. I would rather fix it myself than have to pay for the labor...
Any help would be greatly appreciated...
Merry Christmas...
Jason
Old Dec 24, 2006 | 12:47 PM
ErnieN85's Avatar
ErnieN85
have you done brakes before?........... if so it's not much harder although you will need the right tools you need to remove the caliper mount bracket and caliper. also the lower bolt holding the wheel hub & bearing is behind the lower ball joint and it needs to be disconected. make sur you use a torque wrench and get the bolts replaced & torqued correctly.
Now if this hasn't thrown you Tools and such ask again for torque specs. I'm sure you'll get lots of help. maybe some one near you will even offer to stop in and help.
Old Dec 24, 2006 | 02:06 PM
vms4evr's Avatar
vms4evr
Stay off those high bank roundy round tracks and they'll last longer
Especially the front passenger side... j/k.
I managed to kill the drivers rear after about 8 HPDEs and a year of AX. If you track or AX the car, and especially if you use really grippy r-comps it is going to happen sooner than later.
Get the replacements at Autozone for about $170 or Carquest for about $230. They are the same ones GM uses. Timkens. They come with the wheel sensor built in and new studs. So it's one piece.
Here are some excellent instructions that Jake Latham has with pictures! Their in MS Word. Save off both the front and rear replacement instructions, you're going to need them if you track the car. It is not a horrible job to do at all. The front is easier than the rear.
http://www.jakelatham.com/C5/misc/
Merry Christmas!!!
Graham
Old Dec 24, 2006 | 05:23 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Ha! That is exactly what both my wife and my father said...
WOW! Thanks for the write-ups... I imagine I will be getting on this pretty quick. I was hoping it wouldn't be to bad. Thanks again for the help and MERRY CHRISTMAS!!!!
Jason
Old Dec 24, 2006 | 06:16 PM
IDM's Avatar
IDM
wow thanks im doing this tuesday after christmas! That write up will help up a lot to guide us
Old Dec 31, 2006 | 07:43 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Just wanted to give a public thanks to Pyro1 (Jeff) for pretty much doing all the work in replacing my wheel bearing assembly. If you take away all the time we spent shooting the breeze and drinking home brewed beer, it took us about 1 hr to complete the swap.
Thanks again Jeff for all the help...
And thanks to vms4evr for the link to the instructions. They were spot on...
HAPPY NEW YEAR....
Jason
Old Dec 31, 2006 | 07:52 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
HAPPY NEW YEAR....
Jason
Old Dec 31, 2006 | 08:27 PM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
No problem, I enjoyed it. Wasn't too bad & I enjoyed hanging out and tippin back a few of the home brews!
Old Jan 1, 2007 | 01:58 AM
IDM's Avatar
IDM
Isnt that sweet, I did mine alone, it sucked!
Old Jan 1, 2007 | 08:10 AM
Pizzano's Avatar
Pizzano
[QUOTE=IDM;1558326242]Isnt that sweet, I did mine alone, it sucked![/QUOTE
Thats probably because you only had Bud Light in the fridge J/K]
Old Jan 2, 2007 | 07:10 PM
stngh8r's Avatar
stngh8r
Thanks vms4evr for the instructions. I will be trying to pull this off in the next few days and the instructions were exactly what I was searching for.
Thanks and Happy Modding
Eric
To Wheel Bearing question?
