exhaust install shops
Dec 24, 2006 | 09:00 PM
can anyone recommend a exhaust install shop in the northern virginia area, or is there a write-up about how its done?
also is it hard to do on a scale from 1-10? thanks
Dec 24, 2006 | 09:07 PM
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Andrew,
What are you wanting installed?
Peace
Chip
Dec 24, 2006 | 09:55 PM
St. Jude Donor '07-'08-'10, '14
Quote:
Originally Posted by
AndrewNguyen
Catback = 3 (only because you have to get the rear up HIGH)
Long tubes = 5-6 (not too bad, but some work involved)
If you have access to a lift, take a point off of each...
www.97vette.com has a writeup on a catback...
http://www.ls1howto.com/index.php?article=29 for long tubes...
Dec 24, 2006 | 10:17 PM
Willfulone
Andrew,
Peace
Chip
i wanted to remove my borlas and install some slp straight pipes!!!
thanks for all the help you guys
Dec 24, 2006 | 10:52 PM
It's pretty straight forward, I'd give it a 2 or 3. Have to get the back of the car up high enough to remove the borlas with out cutting them off. Other than that, don't push the hanger bolts up into the frame and you should be good to go...
Peace
Chip
Dec 25, 2006 | 07:52 AM
It's really pretty easy if you can get the car up in the air a bit. Probably a 3 out of 10 in terms of difficulty.
