[Z06] Turnk Mat + Partition
Old Dec 25, 2006 | 12:51 PM
TransAmGT's Avatar
TransAmGT
Default Cargo Mat + Partition
Hey guys...first off Merry Christmas
I got a question:
I got Llyods Z06 mats for my Z along with the cargo mat
I also got a partition...it's doesn't seem to fit with the trunk mat and the partition, only one or the other.
Can this be made to fit?
Thanks!
Old Dec 25, 2006 | 01:16 PM
TransAmGT's Avatar
TransAmGT
here is what i got
i think i got the wrong this
i just wanted the part that covered up the cubby holes in the back
Old Dec 25, 2006 | 04:22 PM
DerekT's Avatar
DerekT
I have that rear mat and the partition and it seems to fit pretty flush together. I just put it in from the driver door and pushed it in and it seemed to fit well enough. The partition makes my car a lot more silant, makes the B&B exhaust seem pretty tame from the cab
Old Dec 25, 2006 | 04:45 PM
JB666's Avatar
JB666
I was running both, for a while.. As Derek said, try putting it in from the front. It IS tight with the mat in, but it did fit in there with a bit of convincing..
Old Dec 25, 2006 | 05:34 PM
hotwheels57's Avatar
hotwheels57
I've got the SOUTHERN CAR PARTS partition and the rear mat as shown. Mine will not work together, just to tight a fit. Now you can buy a two piece mat that fits on either side of the partition w/o a problem. I decided to use the mat anyway up against the backside of the partition and roll the narrow end up against the backside of the trunk area. It covers a portion of the outside cubby holes that way.
Old Dec 25, 2006 | 07:49 PM
TransAmGT's Avatar
TransAmGT
can you post a pic of that
i got the southern car parts partition and trunk mat
I wish i could return it and get the one that just goes in the trunk area....anyone want to buy a cargo mat?
Old Dec 25, 2006 | 09:24 PM
hotwheels57
I don't have a camera right now. You can do it two ways...install the mat so that the Z06 is backed against the trunk side of the partition, aligning the narrow ends of the mat at the openings of the side cubby holes (more as intended). The seamed edge will be beneath the forward edge of the trunk lid, but it stays in place quite well.
That mat is supposed to lay inside the interior and trunk w/o a partition. But, in doing so, the Z06 is backwards in the interior which didn't make sense or look correct.
The way I decided to use the mat is to align the top edge of the mat with the bottom trunk side of the partition. That leaves a "left over" portion of the narrow ends curving up against the back of the trunk compartment. I wanted the Z06 showing correctly as I look into the trunk compartment. I hope that makes sense.
SOUTHERN CAR PARTS has a good reputation. You might inquire if you can return the one piece mat and get the two piece mat instead. It'll probably only cost you the shipping.
Old Dec 25, 2006 | 09:28 PM
TransAmGT's Avatar
TransAmGT
Sounds good I might try that...although I think I might call them tomorrow to see if I can swap it out! Thanks!
Old Dec 27, 2006 | 02:35 PM
TransAmGT's Avatar
TransAmGT
Talked to Jim today at Southern Car Parts and he is hooking me up with the trunk mat and compartment covers and letting me send the cargo matt back. Great customer service!! Thanks Jim!!!
Old Jan 1, 2007 | 07:35 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
My pleasure....glad we coud help you out.
Jim
To Turnk Mat + Partition
