98 Vert - Window Rattle when Up
Old Dec 26, 2006 | 05:57 PM
Pats90's Avatar
Pats90
St. Jude Donor '14-'15
Default 98 Vert - Window Rattle when Up
I have a 98 Vert. The drivers side window rattles only when in the up position. I did a search on the forum and only found references to rattling when the window is down. Any ideas? I am going to take the door panel off - but what should I be looking for. Thanks.
Old Dec 26, 2006 | 06:08 PM
chris308's Avatar
chris308
mines moves back n forth to when its up as well. Some say the bottom of the glass is "glued" in the track which it comes loose from. Something to look at while you have the door trim off. Let us know what you find.
Old Jan 8, 2007 | 11:31 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Did you find out what the problem was??
To 98 Vert - Window Rattle when Up
