Locating the Build Sheet
Old Dec 27, 2006 | 08:04 PM
James E.'s Avatar
James E.
Default Locating the Build Sheet
While reading a very informative post about the C5 Vette, it was stated that the build sheet is in the "front rebar". Can anyone clarify the location of this rebar? Can it be easily accessed? Would love to recover it if it is still there and put it with the original window sticker!!
Can anyone help me? You don't learn if you don't ask
Old Dec 27, 2006 | 08:08 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Front bumper needs to come off to get access to the rebar. Its usually hiding on the passenger (right) side rolled up.
Old Dec 27, 2006 | 08:13 PM
James E.'s Avatar
James E.
Thanks, just how hard a task is it? Put it on a lift?
Old Dec 27, 2006 | 08:17 PM
vet85's Avatar
vet85
i took a trip to the factory last year and asked the man who put them in at the factory he said to take a air compressor ---and blow gun tip put it in the front horn and blow it over to one side and pull it out .
Old Dec 27, 2006 | 08:24 PM
NSTG8R's Avatar
NSTG8R
when i had the front fascia off last spring i pulled mine out and had a look at it.
neat little piece of history.
aside from pulling the fascia .. i dont see any way to really access it easily.
Old Dec 28, 2006 | 07:32 AM
You need to take the front fascia off to get to it. Easier to just order one from the National Corvette Museum.
Old Dec 28, 2006 | 08:48 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Built Sheet
I would just pay NCM and order one, I order a Window Sticker and a Built sheet for my car and had them matted and framed.......looks good!
Old Dec 28, 2006 | 12:13 PM
GUSTO14's Avatar
GUSTO14
Go here and get one...
https://store.corvettemuseum.com/ser...buildsheet.asp
Save yourself a lot of trouble and save a treasure for someone down the road! The museum copy is exact in every detail and a lot easier to get to... unless you want to spend a few hours disassembling your front bumper cover and foam padding. Even then you're likely to get a stained, fragile and barely legible copy... your call...
Good luck... GUSTO
Old Dec 28, 2006 | 12:26 PM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
No it doesn't... just reach right on in and get it.
To Locating the Build Sheet
