tire warm up?
Old Dec 27, 2006 | 10:55 PM
hk940's Avatar
hk940
Default tire warm up?
i am a new vette owner in Houston Texas and it does not get very cold down here. this morning it was close to freezing and the tires were all about 24-25psig. two of the four had tripped the DIC. i reset the DIC and looked at them. they looked ok. i drove the 30 odd miles to work and they quickly warmed up to about 27psig. by the time i got to work they were at the "usual" 29-30 psig. when i got off work it was in the 60's and the tires all read about 27-29psig.
i just wanted to know if this is normal and is it safe to run them like this.
i am use to trucks and the 285-75R16 tires i run on my truck don't seem to do this. is it a product of such a small tire? i would hate to air up and down tires just to compensate for the temp. but maybe this is what i need to do?
thanks,
hk
Old Dec 27, 2006 | 11:09 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Yep, that's what usually happens when the temp drops. Best thing is to inflate to the proper 30psi when outside temps are 60's or so before driving, then when the temps drop you may get the low pressure message for the first mile or so but no biggie. Or you can inflate to about 32 psi so you don't get the low pressure message and go back to the normal 30 psi in the spring. Mine are at 33 for winter.
blk_vet's Avatar
blk_vet
Check your door. 30 COLD!
Old Dec 27, 2006 | 11:38 PM
Bill Vett's Avatar
Bill Vett
I keep them 30 cold ALL year long. If I remember right for every 7 degrees +or - in air temp, you have a 1 lb pressure change.
Old Dec 27, 2006 | 11:44 PM
fst1's Avatar
fst1
hmmmm..... that explains it !
( Been going through the same drill for some time )
Old Dec 28, 2006 | 07:22 AM
The pressure in my tires drop when the temp goes down. I just check them frequently to ensure I have the proper pressure in them.
Old Dec 28, 2006 | 07:26 AM
Tom/99's Avatar
Tom/99
Put 30 psi in them, cold. It's in the owners manual.
Old Dec 28, 2006 | 08:39 AM
steve8's Avatar
steve8
Don't trust a visual inspection for proper inflation.
Old Dec 28, 2006 | 10:48 AM
rws.1's Avatar
rws.1
30 cold ( measured at your ambient temperature)
Old Dec 28, 2006 | 01:01 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
thanks,
hk
Its normal. And if you have runflats and you meant you visually looked at the tires to see if any appeared low, they never will. Even with 0 air pressure they will look fine.
To tire warm up?
