Exhaust extensions vibrating
Dec 30, 2006 | 04:14 PM
I just found the source of an annoying rattle. My stainless steel exhaust extensions. At a certain speed and vibration they rub and vibrate. Is there an after-market rubber spacer for these things?
Thanks guys and Happy New Year!!
Dec 30, 2006 | 07:17 PM
I'm not aware of any but maybe someone else here is. It might not be too hard to rig something up.
Dec 30, 2006 | 09:17 PM
exhaust extension rattle
I had the same problem. They are touching and that will cause an annoying sound at certain RPM's.
1.Loosen the screws on each extension.
2.Jam a wood shim in between each pair to seperate them.
3.Tighten the screws.
You may need to replace some of the screws or redrill a hole or 2 during this procedure.
Dave
Dec 30, 2006 | 09:43 PM
Quote:
Originally Posted by
DaDuck
Dave
I'll do that! Thanks for the tip!
Dec 31, 2006 | 08:22 AM
As a last resort you can always get them spot welded in place. Would only take one weld spot each.
Dec 31, 2006 | 09:27 PM
DaDuck
Dave
I did it and it worked! Thanks for the tip!!
