Leaks!!!
Old Dec 31, 2006 | 01:42 PM
98blackonblack's Avatar
98blackonblack
Default Leaks!!!
Driving home in the rain last night and started getting dripped on pretty bad...Comming from where the tiller and the targa top meets in the front on both sides...Also water on the floor board...dripping on my feet..How do I fix this?
Old Dec 31, 2006 | 01:57 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Maybe replace the seals?? I can see where mine are torn a little bit but not to the leaking stage yet. Hope it helps !
Old Dec 31, 2006 | 02:01 PM
garymilgrom's Avatar
garymilgrom
Have you tried conditioning the seals with something? GM recommends dielectic grease, this is supposed to help expand the seals. I've seen glycerin and other stuff like Zymol Seal, you might try one of these before replacing parts.
My 2001 does not leak, period. I use dielectic grease every few months to maintain the seals. YMMV.
Good luck! gm
Old Dec 31, 2006 | 02:38 PM
rrichar2591's Avatar
rrichar2591
You can also do a search on leaks and find a lot of info. I think there is a sticky on top of the forum that will also give you additional info. Good luck. Let us know how it turns out.
Old Dec 31, 2006 | 03:20 PM
98blackonblack
So I just wipe all the weather stripping down with the grease?
what about the floor board leaks?
Old Dec 31, 2006 | 04:40 PM
98blackonblack
ttt
Old Dec 31, 2006 | 05:02 PM
Blowtorch's Avatar
Blowtorch
I had a minor leak right at the front drivers side of the roof on the way to Carlisle 2 years ago (in a hurricane I might add ). Tried the di-electric grease when I got home and that put a stop to it right away!
Now I put it on the roof seals couple times a year and everything seems
To Leaks!!!
