Well I took the plunge...I ordered heads, cam, long tubes, intake,
t-body, clutch & dte brace...
LG motorsports was very helpful
happy new year to all
Good luck with your install. I did mine this last summer, then had to redo the heads just in early Dec. PITA, but worth doing yourself. What's your setup gonna be?
AFR 205 heads, G5X3 cam, Fast intake w/90mm t/b,u/d pully
LG long tubes w/x-pipe, 42# injectors, and who knows what else!
I did mine last winter, heads and FAST 90 Intake. I did the cam the winter before. Took it in to get dyno tuned and my stock clutch couldn't hold it past the torque peak @ 4800rpm. Installed a new SPEC Stage 3+. You'll love the new found power. Better shop for some sticky tires if you don't have them
