Vehicle Information Request
Old Dec 31, 2006 | 08:42 PM
Mr. Jean's Avatar
Mr. Jean
Default Vehicle Information Request
I'm interested in getting some information on my new toy. I see that some of you work at GM and can get information, if supplied with a Vin number. I'm hoping one of you could help me too.
It's a 2001 Coupe.
My number is VIN 1G1YY22G715118626 1YY07 Coupe
Thank you, for any and all information you can provide.
Old Jan 1, 2007 | 03:20 AM
PM forum member Sponge Vette with this info. He can help you out.
Old Jan 1, 2007 | 09:41 AM
Mr. Jean's Avatar
Mr. Jean
Thanks I'll give him a try later today.
Old Jan 1, 2007 | 09:47 AM
CTSV OWNER's Avatar
CTSV OWNER
Or if you want I can run it for you.
VIN : 1G1YY22G715118626
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2001 CORVETTE COUPE Warranty Start Date : 02/24/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : LANDMARK CHEVROLET ,LTD.
PO BOX 38935
HOUSTON , TX 77238-8935
(281) 820-8100
Selling Source : 13 - CHEVROLET
Site Code : 30402
Business Associate Code : 114879
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 02/24/2001 41 miles 02/24/2004 36041 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 02/24/2001 41 miles 02/24/2007 100041 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/24/2001 41 miles 02/24/2009 80041 miles
36/36000 FEDERAL EMISSION 02/24/2001 41 miles 02/24/2004 36041 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/22/2004 187743 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 24645 miles
12/22/2004 187743 # N4921 - MODULE, LOCAL INTERFACE UNIT - DOOR - LEFT - REPLACE 24645 miles
12/22/2004 187743 # C6041 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - DRIVER 24645 miles
01/28/2004 172298 # N4924 - MODULE, LOCAL INTERFACE UNIT - SEAT - LEFT - REPLACE 19697 miles
01/28/2004 172298 # N4808 - BODY CONTROL MODULE REPROGRAMMING WITH SPS 19697 miles
01/28/2004 172298 # Z7901 - 1-DAY COURTESY TRANSPORTATION 19697 miles
09/17/2003 166757 # N0200 - HORN ASSEMBLY - REPLACE 17458 miles
09/17/2003 166757 # N4924 - MODULE, LOCAL INTERFACE UNIT - SEAT - LEFT - REPLACE 17458 miles
01/11/2001 A18626 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
And here is the build data:
VEHICLE BUILD
Gross Vehicle Weight Rating : 1671 kg (3685 lb) Order Number : DBCX1M
Build Date : 01/11/2001 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
CC3 - TRANSPARENT LIFT-OFF ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE LOW EMISSION VEHICLE
G90 - REAR AXLE-3.15 RATIO G92 - 3.15 PERFORMANCE AXLE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL4 - ACTIVE HANDLING SYSTEM
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - COMPACT 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1AY - STOCK ORDERS PROC OPTION 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
86U - MAGNETIC RED MET W/ TINT COAT
Dave
Old Jan 1, 2007 | 03:56 PM
Mr. Jean's Avatar
Mr. Jean
CTSV OWNER, Thank you so much. I'm pleased to see it has the 3:15 gears, I wasn't sure, as I don't have the car yet. I can read/figure most of this stuff, but I guess on the column bi pass, I'll have to check the car.
Looks like it has a lot of the goodies, I wanted. I didn't see mention of the RED top. The car has both Tops coming, did I miss a code or something? Do you or anyone, see anything I should be concerned about here?
Thanks again for your help, this is a great Forum and I'll try to do my share around here. I'm sure going to enjoy this place and the car, of course.
Old Jan 1, 2007 | 04:06 PM
65GGvert's Avatar
65GGvert
It's not showing the dual top option, maybe previous owner found one. 2001 with auto tranny, you won't need to worry about the column lock. Try it when you get it, with the key out, the wheel shouldn't lock. Looks like it's had some driver seat issues, but not lately. Good luck.
Old Jan 1, 2007 | 07:30 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
CTSV OWNER
Can you run one for me?
2000
1G1YY22G7Y5112318
When I try to log it into MYGMLINK.com it will not acknowledge it.
Old Jan 1, 2007 | 07:54 PM
korte's Avatar
korte
While you're at it,
could you run one on mine too??
1G1YY22G545108794
thanks
Old Jan 1, 2007 | 08:51 PM
CTSV OWNER's Avatar
CTSV OWNER
PM's sent to those who asked. I'm glad to be able to help here on the CF. Trying to do my active part.
Dave
Old Jan 4, 2007 | 01:37 PM
shark454's Avatar
shark454
Dave, Can I ask you to run my 02 Vin? Thanks!! You're great!
1G1YY22G325113988
Mike
Old Jan 4, 2007 | 08:59 PM
TonyNDeb's Avatar
TonyNDeb
Dave, if you could please. On my 02 Z06.
Thanks.. Much Appreciated.
1G1YY12S725132543
If I were to guess, I'd say it's been repaired a lot.
To Vehicle Information Request
