Harmonic Balance Part numbers
Old Jan 2, 2007 | 08:25 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Harmonic Balance Part numbers
Have a friend that may need a new Balancer. There are 2 part numbers listed.
1. 12553474 97-00 LS-1
and
2. 12560115 for 01 LS-1 and LS-6
Anyone know the difference and if you can use the 2nd one on a 99.
Thanks in advance.
Old Jan 2, 2007 | 09:02 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
do not replace the stock balancer with another stock piece.
There are too many other great options out there. There is a rubber lined hub on these stock balancers, which causes them to wobble and sometimes break apart.
Look for an ATI, ASP, Innovative West.
Chris
Old Jan 2, 2007 | 09:32 AM
gonbad's Avatar
gonbad
Don't waste your time and money on a stock balancer. Mine failed and caused some serious damage to the front of my motor.
Excellent time to do a cam swap too. Might as well just take off the front engine cover and cam retainer.
To Harmonic Balance Part numbers
