Leaks More Leaks
Old Jan 4, 2007 | 12:13 AM
98blackonblack's Avatar
98blackonblack
Default Leaks More Leaks
Alright I tried the dielectric grease on all the weatherstripping about 3 days ago....It started pouring while at work today, and when I got into the car the seats were wet, the floorboard was wet and while driving home i was getting dripped on from the top front corner by the top of the pillers on both sides...the weatherstripping doesnt look messed up.....Any input?
Old Jan 4, 2007 | 12:16 AM
RonVette2's Avatar
RonVette2
That sucks sorry to hear that, all I can say is that it gives me flash backs to my first C4 that I bought with 179,000 miles on it
I haven't heard to many stories about this type of issue with the C5's. sorry I can't give you more help.
Old Jan 4, 2007 | 12:27 AM
bobzap's Avatar
bobzap
Default Leaks?
Can't say that I've ever had one.. Yes it's a garage queen, never been out in the rain and only lightly hosed on wash day! Sorry, I hope you solve your problem.
Old Jan 4, 2007 | 12:46 AM
OMG's Avatar
OMG
I must have a self repairing weather stripping, first few months I had it a light rain came and I saw a few drops. I was pretty dissappointed and thought I'll take care of it later since I'm already home.
I totally forget and next time there's a HUGE downpour and I'm on the highway. First thing I think of is greeeeeat...my passenger is gonna get soaked. Instead she stayed dry ( )
Hasn't leaked since. Hope you have better luck.
Then again I just rememembered I might've had a different roof on both times...hmm...
Old Jan 4, 2007 | 12:55 AM
97C5driver's Avatar
97C5driver
Mine does the same thing. Passenger seat especially gets wet. And water leaking on my legf when driving in heavy rain.
I was thinking I would have to replace all the seals but they are crazy expensive!!!
anyone have a solution to this!!!!!!!!!???????????
Old Jan 4, 2007 | 02:29 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
There is an adjustment for the window tip-in.... the instructions have pics which won't paste in here, if you want the complete instructions send me your EMail addy and I'll send em to ya;
Tools Required:
#6 Inverted TORX® Socket
10mm socket
1. Position the window fully up.
2. Remove the large access plug from under the front of the door.
3. Loosen the window regulator front channel mounting nut.
4. Remove the reflector from the trim panel
5. Loosen the jack screw jam nut.
6. Adjust tip in with the jack screw. Turn the jack screw clockwise to tip the window outward. Turn the jack screw counterclockwise to tip the window inward. One turn of the screw equals approximately 1 N·m (0.04 in) change at the top of the window.
7. Tighten the jack screw jam nut.
8. Lower the window.
9. Tighten the window regulator channel front mounting nut.
10. Raise the window and check the alignment.
11. Install the access plug under the front of the door.
12. Install the reflector in the door trim panel.
Old Jan 4, 2007 | 12:49 PM
97C5driver's Avatar
97C5driver
please send to me.......... lucasross06@yahoo.com
thanks.
Old Jan 4, 2007 | 01:18 PM
That's the only other way I know of to possibly get the leak to stop short of just trying some new weatherstripping (rather expensive fix). Hopefully the window adjustment will work for you.
Old Jan 4, 2007 | 01:32 PM
Architect's Avatar
Architect
It took some time but I came up with the perfect solution. Don't drive it in the rain.
Old Jan 4, 2007 | 01:37 PM
QuikZilver's Avatar
QuikZilver
My passenger side leaks into the headliner (gets soaked when raining). Haven't gotten a chance to take a hard look at it, but I think before I bought it, the previous owner may have complained about wind noise, so the stupid dealership put a lot of black RTV into the front and rear of the plastic trim piece. I think they blocked the drain hole on the passenger side. Have to get out there and take a look one of these days, as I drive my Z06 in the rain (prefer to drive it over my 86 Monte Carlo SS in the rain, due to the lack of traction control and ABS in the Monte Carlo).
iridelow's Avatar
iridelow
Tools Required:
10mm socket
Tstar, I would also like the pics as well. Thanks in advance.
kduke1@sc.rr.com
Old Jan 4, 2007 | 01:42 PM
jrose7004's Avatar
jrose7004
I had a F body vert once and I couldn't ever stop the leaks in it so I had to always carry a towel.
Old Jan 4, 2007 | 02:01 PM
VetteFanatic007's Avatar
VetteFanatic007
Tools Required:
10mm socket
I would like the instruction also. Thank You, vdcook2@aol.com
Old Jan 4, 2007 | 02:26 PM
OMG's Avatar
OMG
Damn didn't know leaking was such a common issue...way to go GM.
Old Jan 5, 2007 | 02:59 AM
tstar's Avatar
tstar
Default EMails Sent
OK, I think I covered all the PMs and requests here in the thread if I missed someone please PM me... I think I wore outlook out!
Old Jan 5, 2007 | 03:06 AM
tstar's Avatar
tstar
Well at least they are consistant! This is my fifth vette I've had C3s, a C4 and now a C5 and they ALL had or developed a leak at the windows at some point. I always blamed the removable top, I wonder if the FRCs are having a problem?
Old Jan 5, 2007 | 05:48 AM
tavaresv's Avatar
tavaresv
Tools Required:
10mm socket
Although I do not have a problem with this now, I am amassing a bunch of tips and ideas for the future---just in case.
So if you could email me the pix. too, I would appreciate it.
tavaresv@yahoo.com
Thanks!
Vilmar
To Leaks More Leaks
Old Jan 8, 2007 | 11:21 AM
TonyNDeb's Avatar
TonyNDeb
If you could send them to me as well. My Z06 leaks bad, and if I hit the wind right, I can feel the cool breeze.
t.bareika@charter.net
Old Jan 8, 2007 | 12:29 PM
N0TDADYS_98's Avatar
N0TDADYS_98
please send to me
davidnewman3@hotmail.com
Old Jan 8, 2007 | 12:44 PM
grumpyone's Avatar
grumpyone
Default Leaks
I've got an 04 coupe which I experienced the same problem and thought it was the weatherstripping. Took to the dealership and found out there is weatherstripping in the removable top that was bad. They replaced the weatherstripping in the top and it has been ok for the past 6 months.
