fuel rail cover question
Old Jan 4, 2007 | 06:18 PM
jeff49's Avatar
jeff49
Default fuel rail cover question
Do the fuel rail covers on the 2001 just pop off when pulled or is thier something to unbolt.Dont want to break anything.Thank you.
Old Jan 4, 2007 | 06:20 PM
Rick@CTCORVETTE's Avatar
0Rick@CTCORVETTE
Former Vendor
Nothing to unbolt. Just pull them off.
Old Jan 4, 2007 | 06:29 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
A gentle tug should do it and then just wiggle them out. They are a little snug back near the firewall.
Old Jan 4, 2007 | 06:44 PM
terand's Avatar
terand
Is this the same for 03
Old Jan 4, 2007 | 06:58 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Yes, all the same. As a suggestion I would pop the bottom points of the cover 1st, then the tops. The bottom attachment points are mechanical "pins & clips" as the top is just a plastic "C" molded into the cover itself.
Old Jan 4, 2007 | 07:21 PM
terand's Avatar
terand
Thanks Old55
Old Jan 4, 2007 | 07:35 PM
jeff49's Avatar
jeff49
Thanks alot
Old Jan 5, 2007 | 07:37 AM
Just pulls straight off. Remember to take off the oil cap and then you will have to maneuver the driver's side cover around the braided fuel line. Thankfully the covers are flexible. I've found that putting a little masking tape around the fuel line before trying to remove the cover helps prevent scratches to the cover.
To fuel rail cover question
