Hip Replacement and 6 speed
Old Jan 4, 2007 | 07:50 PM
JUSAKD's Avatar
JUSAKD
Default Hip Replacement and 6 speed
Question anyone on the forum drive their 6 speed after Hip Replacement surgery.
I will be getting a new left hip in the next two weeks.
I worry about working the clutch after surgery. I mean after a few months.
Put the Vette in storage and I wonder if I will be able to drive it.
Old Jan 4, 2007 | 08:06 PM
pittguy79's Avatar
pittguy79
Having gone through a replacement myself at a younger age (less than 40) when recovery times are quicker I would estimate, presuming your age to be 55 or less, that you are a minimum of 10 to 12 weeks post surgery before driving the vette.
Good luck with the surgery!!
Old Jan 4, 2007 | 08:50 PM
Hotrodzz3's Avatar
Hotrodzz3
I had a total right hip replacement a year ago at 56 years young. I was driving my 6 speed vert and riding my Harley in 8-9 weeks. They weren't long rides but I was able to do it, and besides getting in and out is going to be the challenge not driving it. It will be easier if it's a vert but if the desire is there you'll find a way in. Now that I've had the hip replaced I can't sit in it as long as I used to. Seems as though I can go a couple of hours then need to get out and stretch. You should be up and walking on it withing a day or two, so by the time you get to where you can drive again your leg will be plenty strong for the clutch. Best of luck with the surgery, let me know if I can answer any other questions
Bob
Old Jan 5, 2007 | 07:34 AM
No actual experience to offer, but hope the surgery goes well and you don't have any problems driving the car.
Old Jan 5, 2007 | 08:44 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Had a total left hip replacement done this past June. It was (still is) "sticky" getting in and out of the car. You've got to be careful about the "angles" (I'm sure you've heard this term by now) you place your body vs. surgery leg when getting in/out of your C5 (or any car). I started driving my C5 about 2 1/2 months after the surgery. My car is an A4, so can't give you any info on how my leg would have held up using a clutch. Personally, it would have been tough on me IF I had a clutch. But, that's me and everybody heals differently. All in all, it went very well, but, as noted before, use caution when entering/leaving the car. Although, my car is stored for the winter now, I'm certain when Spring rolls around, I'll be just as good as new.
Good luck w/ your surgery....
Old Jan 5, 2007 | 11:13 AM
99NBVette's Avatar
99NBVette
Had both hip done it will be 4 years in Feb at 58. Hip are great no problem with in or out of vette or 6 speed. Many Doc's can do the job but some are better than others! Good Luck!
Old Jan 5, 2007 | 12:08 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Had mine replaced 9 years ago at age 45. Only off work for less that 4 weeks and driving in that time (not the Vette however), that took a few more weeks. Absolutely no problems whatsoever with the hip or driving my MN6. In fact, this surgery was way easier than the knee cartilage surgery I had earlier (I'm an old, key work old, motocrosser and runner and really trashed my body in my younger years). So, no worries, you'll be behind the wheel in not time! Good Luck - Zuti
Old Jan 5, 2007 | 12:15 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default drive on...
while i've still got the originals.. , my wife has had both of hers replaced and she can drive the m6 with no problems whatsoever...just be careful getting in and out, you may not be able to draw your knee(s) up as high as before. clutching is cake... dave
Old Jan 5, 2007 | 04:50 PM
photoguy's Avatar
photoguy
Shouldn't you feel better after having it replaced? If not, I wouldn't have the surgery. JMOP
Old Jan 5, 2007 | 05:11 PM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
I'm driving my 99 because the PO had both hips replaced and couldn't operate the car. My guess after reading the others comments, is that he didn't do rehab.
Old Jan 5, 2007 | 05:42 PM
rustyguns's Avatar
rustyguns
Default rehab
gotta do rehab! no pain no gain !
Old Jan 5, 2007 | 05:59 PM
roadstr899's Avatar
roadstr899
Had a right hip replaced three months ago. It's a breeze, was expecting a whole lot more pain from surgery than I had. Nothing to speak of really. Operating a clutch afterwards? Not a problem if you do the rehab and exercise the leg religiously. Rehab lengths depends on how long you waited and how weak the leg becomes before you have the procedure. You'll be walking the next day. I spent two weeks on a walker, another three weeks using a cane, and then on my own. You'll be restricted for about 6 weeks on twisting, crossing your knees, and bending hip past 90 degrees. Its a good move, worth the small amount of time to recover. Paying for it is the only part that really hurts even with insurance. Go for it! (Have your walker flamed and a cup holder and a HUD installed before you take it out though! Hard to look cool on a walker!)
Old Jan 5, 2007 | 08:09 PM
JUSAKD's Avatar
JUSAKD
Thank You for the information. I feel better knowing we can still drive it.
Old Jan 20, 2007 | 08:17 AM
Z28TOZO6's Avatar
Z28TOZO6
Thanks for posting this. I am going in on the 29th of January for a right hip replacement. My car is already up for the winter so I wasn't planning on driving it for a few months and it is my right hip anyway. Getting in and out is what I heard is the clincher.
Does anyone know how long it is before you don't have to woryy about the "angles" anymore? I mean at some point the bone should attach to the prosthesis, and you should be better or as good as new, right?
Old Jan 20, 2007 | 08:39 AM
OrangeVegaGT's Avatar
OrangeVegaGT
No experience with the hip and good luck with the procedure, but just wanted to comment that I bet you wouldn't find a thread like this on an EVO or WRX forum.
I think it's wonderful just how multi-generational Corvettes are.
Old Jan 20, 2007 | 09:38 AM
jarsdad1's Avatar
jarsdad1
Good luck with the surgery. I'm due for one, but I've been putting it off (pain hasn't become unbearable yet). Since yours is a right hip, if you get caught speeding, you can tell the officer your prosthesis slipped out of place and you "accidentally" stepped too hard on the gas.
Old Jan 20, 2007 | 09:40 AM
JUSAKD's Avatar
JUSAKD
HI ALL !!!
Just wanted to say I started this thread. Thanks for all the great encouragement.
I just had the surgery MondayJan 15.
I'm at home today Saturday recovering. I made it !!!!
Yes you must do rehab (exercises).
They are painful but necessary.
I pretend I'm pushing in the clutch and listening to the engine.
Helps make it easier.
Thanks Again.
To Hip Replacement and 6 speed
Old Jan 20, 2007 | 09:49 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
HI ALL !!!
Thanks Again.
Good Luck, and many,many happy miles!!
Old Jan 20, 2007 | 02:28 PM
sooz's Avatar
sooz
Everyone heals at a different rate. Your surgeon will x-ray your progress. Most important is not flexing that hip to the Vette's angle of the seat until you are medically cleared. You don't want that sucker to pop out of place. Hip replacements generally do well. Good luck!
Sooz RN
Old Jan 20, 2007 | 08:03 PM
doubleOseven's Avatar
doubleOseven
Im just about into my 6th week had the right one done. Having trouble driving but walking gets better and better every day. Should be able to ditch the cane soon. Im having trouble with bending my knee but thats prolly from lack of use since I put off the replacement for almost 4 years,
