CE light and Code??
Old Jan 5, 2007 | 09:13 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Default CE light and Code??
I got this code P0430 = TWC System Low Effiency Bank 2-A
anyone have a clue what this might be?
Old Jan 5, 2007 | 09:53 AM
mojo1's Avatar
mojo1
anyone??????
Old Jan 5, 2007 | 09:58 AM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
Here you go.
http://www.obd-codes.com/trouble_cod...old-bank-2.php
Old Jan 5, 2007 | 10:03 AM
mojo1's Avatar
mojo1
Originally Posted by OrangeVegaGT
Thanks !
Old Jan 5, 2007 | 10:12 AM
OrangeVegaGT
I believe that emission systems are waranteed for seven years by law, so you may want to take it to the dealer if you are out of waranty.
De nada.
Old Jan 5, 2007 | 11:03 AM
mojo1's Avatar
mojo1
De nada.
I have headers and highflow cats, I wonder if that will be a problem. The car was in for a new gas tank and heater core and the light came on after that .I took it back and he told me it was the code for cat s and that all they could do was clear the code. It came back on about 4 days after that. The headers have been on at least a year with no codes, I still think its something they did but cant figure out what.It seems like I read some where that to get to the gas tank the transmission has to come out and the exhaust too? Not sure about that . I might try a different dealer and see what they say , was not to happy with the service at this one !
Old Jan 5, 2007 | 11:10 AM
BlackZ06's Avatar
BlackZ06
The transmission doesn't need to come out, and the mufflers (not the entire exhaust) only need to be removed if it's an automatic to get the fuel tanks out. Manual tranny vehicles no need to remove mufflers. That's for a stock vehicle. If you have a non-stock exhaust they MAY have had to remove some/all of it to get to the tanks.
Old Jan 5, 2007 | 11:30 AM
mojo1's Avatar
mojo1
Its a manual , the work was done under warranty , just trying to figure out if the codes are caused by some thing they did or not ..
Old Jan 11, 2007 | 08:05 AM
mojo1's Avatar
mojo1
Still getting codes , called the dealer back that did the work and they are no help .I can't figure out what they did that would cause the code but it was no problem before. Its almost out of warranty and not sure if it would be covered anyway because of the headers but it almost has to be something that was done when they had it ?????
Old Jan 11, 2007 | 09:50 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You get that code with highflow cats.
Old Jan 11, 2007 | 01:04 PM
mojo1's Avatar
mojo1
I didnt for about 20,ooo miles so why now? The car is going to a diferent dealer today !
To CE light and Code??
