[Z06] LG pro O2 sensor question
Old Jan 6, 2007 | 11:45 AM
SteveDM's Avatar
SteveDM
Default LG pro O2 sensor question
I just got a set...with square O2 sensor extentions. I have an 02 Z06...and have heard I need the flat...not square connectors...is there any truth to this? Those of you who have done an 02 please chime in...I know the newer ones are square.
thanks.
Steve
Old Jan 6, 2007 | 12:55 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The only extensions that should come with the LGs would be a square to flat adaptor to run rear O2 sensors in the front O2 sensor plug. Any other extensions could be if you have a newer set with all 4 O2 bungs to make rear O2s reach the x pipe.
Old Jan 6, 2007 | 07:13 PM
SteveDM's Avatar
SteveDM
The extensions that came with mine are only that...extensions...square to square....does anyone know if a 2002 should use a square to flat?......If I have a newer set of pro's do the fronts just go to the front and the rears to the rear?
Old Jan 6, 2007 | 09:17 PM
Skypilot797's Avatar
Skypilot797
http://www.ls1howto.com/index.php?article=29 maybe this will help you.........
Old Jan 7, 2007 | 09:28 AM
SteveDM's Avatar
SteveDM
ttt someone must have experience with this
Old Jan 7, 2007 | 10:08 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
My mind just went blank on what i did.....but call LG, they helped me with all of my questions.
Old Jan 7, 2007 | 08:36 PM
SteveDM's Avatar
SteveDM
ttt
To LG pro O2 sensor question
