Oil leak ! pic inside - please help!
Old Jan 6, 2007 | 09:21 PM
SpeedUp's Avatar
SpeedUp
Default Oil leak ! pic inside - please help!
This appears to have been leaking for some time. I also have a few small spots on the garage floor (size of a dime and quarter). Has anyone else had a similar leak?
02 Vert - Auto trans
Old Jan 6, 2007 | 09:25 PM
photoguy's Avatar
photoguy
Looks like you have a problem. Get it checked ASAP!
Old Jan 6, 2007 | 09:26 PM
molten vett's Avatar
molten vett
I had a leak like that and couldnt figure out where it was coming from.It would leak worse when i drove it hard.Turns out my harmonic balancer bolt had worked its way out and the balancer was coming off.This also caused the front seal to spew out oil under hard acceleration.I had the balancer and front seal replaced also the balancer bolt. Havent had any problems since,i hope this helps
This may also cause your ac belt to slip off.
Old Jan 6, 2007 | 10:24 PM
Burgie's Avatar
Burgie
Curious, with that happening did you happen to notice a rythmic vibration from about 60 up either accelerating or decel?
Old Jan 8, 2007 | 08:10 PM
SpeedUp's Avatar
SpeedUp
Default Update
Based on some tips from others, I went around and checked for loose lower oil pan bolts. I was shocked to find that most were loose! I went around and snugged them up. Hopefully that will help!
Is it normal for those to be that loose??
Old Jan 8, 2007 | 08:25 PM
pdd000's Avatar
pdd000
what did you torque them too?
Old Jan 8, 2007 | 08:50 PM
SpeedUp's Avatar
SpeedUp
around 15ft/lb
Old Jan 8, 2007 | 08:53 PM
Blown 346's Avatar
Blown 346
It isnt normal for them to be that loose, but from the motor getting hot and cooling down, it can cause the bolts to work themselves loose over time.
To Oil leak ! pic inside - please help!
