Instrument Panel Lighting
Old Jan 7, 2007 | 12:59 PM
2K4Vert's Avatar
2K4Vert
Default Instrument Panel Lighting
It may have always been this way, but I noticed the left center of my instrument panel cluster (IPC) appears to be dimmer than the rest of the IPC. From around the 0 mph left to across the tach to about the edge of the oil pressure gauge. Could be there is less white surface area to reflect, but there is an obvious dimness.
I took the car to the dealership. According to my receipt, they dismantled the IPC, replaced something (no part number shown), and reassembled the IPC. Whatever they did, did not correct the problem. Lucky it was warranty work.
Anyone else have this problem?
Thanks...
