my car isnt starting even tho the radio comes on and the AC/HEat will come on, what do you guys think or suggest it is? i was thinking the battery needs changing but then again, i drove it yesterday, and i am teh 2nd owner, its a 2001 vette, and i kinda drove in teh rain yesterday...so..im thinkin maybe new battery? but why is the RADIO come on? and all the lights?
its an AUTO.....i heard NO CLICKING sound at all...nothing...dead silent....how do i pull the codes (im a corvette noobie)
im thinkin maybe i just need to change the battery cause everything seems fine...only thing is, i was getting a warning that my left front and left rear tire had low pressure, i kept driving and it wasnt there anymore...
What do you mean you kinda drove in the rain? You either did or you didn't. Did you drive through any deep puddles? Did the D.I.C. pop up with any indicators there might be a problem? Have you consulted the owners manual? If its the original battery I would suspect it has gone bad and doesn't have the cranking amps to even pull in the solinoid.
Have you tried jumping it?
what i meant by KINDA driving thru rain was that it rained and it was wet outisde, and i did hit a puddle. (small one) and im about to jump it, but im thinking if i should jsut replace the battery....
ummm.....this is odd..i went to check if it would start...and it STARTED
So it started normally? Interesting... You can try using an eraser on the resister that is on the key. It will clean it up and possibly that is your problem. Worth a shot. Good Luck!
From: West Hollywood California ! Now Miami, Florida
ttt
i would say if you have the stock battery in there still, take it out, as many problems can arise from it. Put in a red top or yellow top optima .. get a full charge at any auto zone or jiffy lube .. . or any good mechanic and you should be good.
i had some what of the same problem and i thought it was my alternator . but after a full charge the problem has not come back since.
fyi . just my two cents.
since it's an Auto, I would wonder if the interlock switch on the tranny may be causing this - by interlock, I mean the switch that makes sure you're in park before you can start it.
If it were the battery I would expect that you would hear clicking if the voltage was weak, and I would not expect that it would suddenly start just fine....
When you start the car in teh past, did the display show "charge system fault". If so, its the battery. I also have a 01 and not to long ago the same problem happened to me. Everything would turn on except for the engine. I but a new battery and presto, it fired right up.
sometimes cars do stupid things.....if it was on a hill....sometimes u have to take it out of park and then put it back in park and make sure its in all the way somtimes the car will think its in reverse......happend to me the 2nd day i had it.....no prob since
