too simple for C5 tech
Old Jan 12, 2007 | 03:04 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default too simple for C5 tech
any hints for easy/easier plug wire removal? trying not to rip or destroy wires...seem way tight. dave
Old Jan 12, 2007 | 03:14 PM
CSC5's Avatar
CSC5
From: Yeah, well, you know, that's just, like, your opinion, man.
Not from me. I destroyed most of mine!
Old Jan 12, 2007 | 03:18 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
wear gloves - it is a knuckle-skinning operation... You can try the usual approach of tying to twist them before you try to remove them. I only did it once, when I was putting on a new set, so I didn't worry about being gentle...
Old Jan 12, 2007 | 04:27 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
just twist them first...wiggle them around. pull by the boot, NOT THE WIRE!!!! thats why people break them. changing plugs and wires is easy on this car provided you have the right sockets. do you have extensions and swivel heads? that will help a lot! it took me about 30mintutes to do all mine. quite easy. my 96' suburban takes me like 1.5hrs!!! and THAT is an open engine bay! LOL
Aj
Old Jan 12, 2007 | 04:35 PM
hotwheels57's Avatar
hotwheels57
A spark plug boot removal tool will come in handy. There's many variations of the tool, all are inexpensive, but basically they all hook onto the boot and gives you something to pull on other than the wire.
This is one variation of the tool from SUMMIT RACING. When you re-install, use some dielectric grease on the boots to make future removal much easier. The boot tends to vulcanize to the spark plug w/o a lubricant.
Old Jan 12, 2007 | 04:40 PM
Tigershark3's Avatar
Tigershark3
Hint: Before you pull the boot away from the plug make sure you've broken it loose from the end of the plug. You'll feel it - then pull by the boot. $.02
Old Jan 12, 2007 | 04:45 PM
terry621's Avatar
terry621
From: Peterborough"I'd rather be topless than all couped up" Ontario
St. Jude Donor '07-'08-'09-'10
Default Good luck
Ist and 2nd time
Old Jan 12, 2007 | 04:51 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
Default pheww!
glad i'm not the only one to encounter difficulties here... thanks for the input. LLTF (long live the forum...) dave
To too simple for C5 tech
