radiator overflow tank leaking
Old Jan 13, 2007 | 02:44 AM
newyorknick's Avatar
newyorknick
Default radiator overflow tank leaking
greetings all.....my radiator overflow tank has sprung a leak at the hose connection....the tank is cracked and i have ordered a replacement.....i would like to replace it myself.....any suggestions for a first time do it yourselfer ??? thanks in advance from the proud owner of a 2000 white coupe
Old Jan 13, 2007 | 02:49 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
It is an extremely easy process.
Remove the hose and clamp.
Put a "cork" in the hose to/ftrom the radiator.
There are two or three (can't remember) that hold the tank to the vehicle - remove those and the tank is removable.
Reverse the process for installation.
Be SURE that the coolant levels are correct (it will be necessary to run the car until it is fully heated up, then recheck levels).
Good luck.
Old Jan 13, 2007 | 08:19 AM
Simple enough to do. Just be careful and not drip coolant all over the engine compartment/fender.
Old Jan 13, 2007 | 08:47 AM
bobc997615's Avatar
bobc997615
Make sure you inspect for plastic pieces of the tank nipple that might be inside the hose. The tank hose nipples tend to crack where there is a brass insert (to strengthen the nipples) at the "tee".
To radiator overflow tank leaking
