Headlight problem
Old Jan 13, 2007 | 12:10 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Default Headlight problem
My passenger side low beam is intermittent. I just took the cover off and checked that the bulbs are tight, and they are. But when I wiggled the wiring harness, I could get it to come on and go off. I'm guessing either a broken or frayed wire, or maybe even a bad ground somewhere.
Any ideas?
Old Jan 13, 2007 | 01:27 PM
MAC5's Avatar
MAC5
You didn't say how far back from the connector you've gone that the flickering continues. I'd try to determine how far back from bulb connector the break in the wire might be. Start moving the two wires starting from the bulb back until the flickering stops. If the damage is close to the connector you could purchase a new connector at Advance or Autozone and splice it in.
