Fuel Door Won't Open
Old Jan 13, 2007 | 02:28 PM
joker man's Avatar
joker man
Cruising
Default Fuel Door Won't Open
Fuse is good. Pushing release button does nothing. Emergency release cable will work.
Now what???
Old Jan 13, 2007 | 02:31 PM
LF97C5Vette's Avatar
LF97C5Vette
Codes in DTC? If you've lost comm. w/ one of the modules (i believe the BCM controls the hatch/fuel door buttons but i could be wrong) that may be the problem. Otherwise - i dunno, so GL to ya!
Oh - i'd also remove the console and check the connection to the button, make sure it's actually working and not broken/disconnected/melted etc...
Dan
Old Jan 13, 2007 | 02:32 PM
rickko's Avatar
rickko
Electrically check switch and relay maybe.
Old Jan 13, 2007 | 03:21 PM
hotwheels57's Avatar
hotwheels57
If you, dealer or previous owner has removed the center console in the past, the wires might have gotten pinched or the male/female connector might have come loose.
Some have complained about water getting into the mechanism under the lid, which damages it. Some have had success in removing the mechanism or lubing the mechanism with WD40 or favorite lubrication.
Old Jan 13, 2007 | 03:32 PM
Could be bad button or loose connection.
Old Jan 13, 2007 | 05:16 PM
EscapePod's Avatar
EscapePod
Happened to me last summer, right after radio work (by myself). I've had the console out six or seven times without problems, but the last time (actually, second to last time ), I didn't "lock" the connector for the fuel door button completely. When I got home after the fuel fillup, off came the console one more time -- reconnect the button wire (tightly this time) -- door works correctly.
So.... the question is, did you have the console off for a shifter install or radio or climate control work?
Old Jan 13, 2007 | 08:13 PM
joker man's Avatar
joker man
Cruising
Had clutch replaced recently (LPE650TT). Would console have been involved???
Old Jan 13, 2007 | 08:32 PM
EscapePod's Avatar
EscapePod
According to page 4-10 in Volume 1 of the 2001 Corvette Shop Manual, yes ... the console must be removed.
Old Jan 13, 2007 | 09:00 PM
BC_C5's Avatar
BC_C5
Yes, it is also common for the connector to get pulled out on removal. It happend to me after the dealer serviced a clutch issue. I did not realize until a few weeks later when I required petrol.
Cheers
Alan
Old Jan 13, 2007 | 09:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
check and see if the switch is plugged in.
Old Jan 14, 2007 | 12:59 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Sounds like it was left disconnected. As a last ditch effort incase you are running super low on fuel, pull the carpet back on the inside of the car right behind where the fuel door is. You'll see the steel cable there. just give it a little tug and it should open the fuel door manually.
Old Jan 14, 2007 | 02:46 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Ding, ding - I believe we have a winner
Old Jan 14, 2007 | 11:52 AM
EscapePod's Avatar
EscapePod
Joker Man already stated in the first post that the emergency release for the door works.
Old Jan 14, 2007 | 05:13 PM
joker man's Avatar
joker man
Cruising
Thanks for all the info. Now how do I remove the console or whatever I need to do to hook the switch back up???
Old Jan 14, 2007 | 05:25 PM
HawkIVette's Avatar
HawkIVette
Here - copied from tech tips for Ripper shifter install by Chris Byrd
https://www.corvetteforum.com/techti...D=28&TopicID=1
Center Console Removal: Lift center storage bin. Locate the two plastic tabs at the rear of the bin. Lift off plastic tabs and locate the two 10mm nuts.
Remove the trim piece with the traction control button by gently prying up. Disconnect the traction control harness and the variable suspension selector harness (if equipped). Disconnect the accessory plug wiring harness. Remove the two 10mm nuts.
Should be able to get it off and on from this to get done what you need to.
Under "OTHER" on the links line at the top of every Forum page, there is a link to "Tech Tips". Members should use these more often. Other forum members have written these to help fix or mod anything you want to do to a Vette, well......almost anything. For all else, just ask EnglandGreen and he will tell you how to do it.
Old Jan 19, 2007 | 01:22 PM
joker man's Avatar
joker man
Cruising
THE FORUM NEVER CEASES TO AMAZE !!!!! thanks to all and especially HAWK for the suggestions and pictures. Plug was off of switch.
JOKER MAN
Old Jan 19, 2007 | 01:33 PM
USA Muscle's Avatar
USA Muscle
I had this happen a couple of years ago while it was under warranty and in mine case it was a bad solenoid. It was replaced and everything has worked fine since.
To Fuel Door Won't Open
