Okay, I'm retarded.......the guy supplied (2) air bridges.
Anyhow, where should I put the MAF sensor ? I noticed the MAF housing is a smaller diameter than the filter.
Do most of you put it by the filter or near the throttle body ?
Do you have a TRAP or a TRIC or the older style intake?
Sounds like you have a TRAP, since the trap setup uses two pipes that look like airbridges.
One takes the place of the stock airbridge, the other routes from the maf down and under the front cross member.
The filter is behind the license plate inside the fascia.
I opened up the bottom of the fascia and installed the filter up through the bottom and connected it with the lower tube and snugged up the clamp, then hooked it to the maf, then worked the airbridge into place and lined it all up before tightening all the clamps.
Here is a pic of my trap installed - you can see the black carbon fiber lower tube running down under the cross-member -
The link above my post is to the TRIC intake which does not use the lower "airbridge" tube, instead just hangs the filter in the location of the (removed) stock airbox.
