[Z06] changing all fluids.. a little help
engine-
trans-
rear-
clutch-
procharger-
Oil Filter - K&N 1007,
Transmission - Royal Purple Synchromax
Differential - Royal Purple Max-Gear,
Clutch - Valvoline Synthetic
trans- AmsOil ATF - 4qts
rear- Royal Purple 75-90 or 75-140 - 2qts
clutch- Valvoline SynPower DOT 3/4 full synthetic - have to do this little by little via the reservior unless you have a remote bleader. 1qt
brakes- Valvoline SynPower DOT 3/4 full synthetic - 2qts will be enough to replace the fluid in the reservior and fully flush/bleed the system
power steering- GM spec fluid (valvoline PS fluid made my pump noisy) - 2qt empty reservior and fill back up with new fluid then drive for a day, repeat cycle until you go through a couple quarts.
procharger- ???
Applicable AMSOIL products:
Engine Oil:
AMSOIL Series 2000 0w30
AMSOIL SAE Synthetic 5w30
AMSOIL SAE Synthetic 10w30
Tranny (takes about 3.7 quarts so get 4 quarts):
AMSOIL ATF
Diff (takes about 1.7 quarts so get 2 quarts):
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
Note: Diff takes 4 oz of limited slip friction modifier. Some fluids such as the AMSOIL Severe Gear come with this fluid pre-added. I've been using this gear lube on the track for several seasons now and have not ever needed to add extra friction modifier due to diff chatter. If diff chatter does occur, AMSOIL makes a friction modifier:
AMSOIL Slip-Lock Differential Additive
This comes in handy for the DIYer:
AMSOIL Hand Pump
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
