Spark plug wire touching header.
Old Jan 14, 2007 | 01:02 AM
99torchredlb's Avatar
99torchredlb
Default Spark plug wire touching header.
My spark plug wire is touching my header. Will that cause a problem?
With the plug wire going bad or what?
thanks
Old Jan 14, 2007 | 01:19 AM
The Spark's Avatar
The Spark
Will probably burn a hole in the wire and short out - killing the cylinder.
Or will burn it in half.
Keep the wires away from the headers.
This was pretty common in my high school days. You could open the hood on the car at night and see sparks jumping from the wire to something metal.
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Jan 14, 2007 | 01:40 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I have the same problem, With one or two wires.
Solution?= Im not sure yet, But I have some heat wrap stuff (cloth like material) I cut a peice of and placed between wire and header, temporary until i look for something better.
Old Jan 14, 2007 | 05:29 AM
Blown 346's Avatar
Blown 346
I also had this problem with cylinder number 7. ( the back plug wire on the driverside).
I used a spark plug wire sleeve and slipped that over and no problems since.
Old Jan 14, 2007 | 11:01 AM
The hot header pipe will burn though the spark plug wire's insulation. Not a good thing for keeping your engine running smooth.
Old Jan 14, 2007 | 11:02 AM
99torchredlb
thanks for the imput
Old Jan 14, 2007 | 03:33 PM
94legaleagle's Avatar
94legaleagle
There is a product out there called "Cool Sox" which is an asbestos or some type of heat resistant material that goes over the spark plug wire like a sock, and is supposed to help guard the spark plug wires - I notice a little marking on my plug wires after 800 miles, so I'm going to install the Cool Sox as part of my head / cam project
Old Jan 14, 2007 | 03:58 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
did this with mine...headers are HOT, wires are $$$, cool sox!
Old Jan 14, 2007 | 04:48 PM
Patches's Avatar
Patches
I have the equivalent 2000 deg. F Fire Sleeves from Taylor along with the 10.4 mm Taylor Thundervolt wires that have a smaller boot to avoid touching the primaries. Got mine at Thunderracing.com.
Old Jan 14, 2007 | 08:08 PM
Eritosthenes's Avatar
Eritosthenes
Was this the result of a bad repair? Or maybe a mod that didn't fit? I may be new to the world of Corvettes, but I'm having a hard time believing BG built it that way.
Old Jan 14, 2007 | 08:26 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have the cool socks and also reused the GM aluminum boots to further protect my plug wires. I hear that the tube on the LG most forward tube on the passenger side has it fair share of burning wires. Hope you get it worked out, because it will blow the connectivity of the wire and create a very rough running car, because you are not running on all eight cylinders.
Micah
Old Jan 14, 2007 | 09:45 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Thats what I have too
Old Jan 14, 2007 | 10:12 PM
99torchredlb
Micah
Thats the one its hitting the spark plug wire boot is right against it.
Old Jan 14, 2007 | 11:04 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Very common, a set of cooling socks will work, but make sure you don't get the ones that only reflect 500 degrees, there is a set that reflects 1500 plus degrees. I know that WEST COAST CORVETTEs sell thems. You could try the boot shields that were on the stock set (if you know what I am talking about) and if it is still touching take a zip tie and tighten just enough to lift it away from the pipe.
Good luck.
Micah
Old Jan 15, 2007 | 09:53 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Micah
Old Jan 15, 2007 | 10:37 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
The factory provides heat shields on the stock wires. It's when custom headers and wires are installed, that it can become a problem.
Old Jan 15, 2007 | 11:19 AM
tiojames's Avatar
tiojames
I bought the semi-rigid hi-temp insulators from Summit instead of the cool sox. They allow you to form the shape to keep the wires where ever you want them. The cool sox can't do this.
To Spark plug wire touching header.
