I notice that the gas pedal is less responsive (takes more pedal to get the same go...) when I am in cempetitive mode....
In two C5Zs, I made passes at the drags in Competitive Driving mode and it had no adverse affect on my time slips. And it helped keep the car off the wall both times that it got loose on the 1-2 shift.
As for the dyno, the car is strapped down and not likely to either spin the wheels or create yaw. So most folks turn off TC/AH on the dyno. But no matter, power produced should be unaffected either way.
Funny thing, Ranger (because Ive read that from you before and its why I always leave the system on) but both of my Z06s (03 and 02) have felt a little sluggish under Comp Mode.
I am not saying that there is an adverse effect on HP or performance with competitive mode enabled - but there is a definate difference in the pedal.
Say normal driving 1/3 down on the gas pedal gets you 33% throttle (theoretically here people, I don't want a tech head jumping down my throat) when in competitive mode 1/3 down on the gas yields 20% throttle - but you can still gain the full 100% with it to the floor.
The car also seems to have a quicker and snappier steering response with AH and TCS turned off...
Competitive Driving mode is benign unless the steering position sensor and the yaw sensors disagree on the intended vs projected path of the car. Then and only then is countervailing brake action triggered. That's not a condition you are likely encountering on the street.
Many thread in the archives on the perils of street driving (or drag strip) with Active Handling turned off. Suggest new owners read a few to become aware of the risks involved in turning the system off.
Comp mode limits the worst that can happen but has no adverse affect whatsoever on the acceleration of the car in straight line.
Ranger
Agreed, also, active handling is designed to come into play if it senses the car is going out of control. (ie, in shifts as Ranger said)...You're not shifting the car on a dyno so unless you've got so much power that you start to spin the rollers on the dyno...active handling should be a non issue.
Active Handling is designed to assist the driver when the car either oversteers (the rear end is "kicking out" or "coming around") or when it is understeering (less turn rate than commanded by the steering wheel). Since the car is strapped down on the dyno and you wouldn't be "turning" then AH would not engage. AH doesn't care about shifting. It also doesn't care about tire slip, that is what traction control manages (which you'd have to have OFF for a dyno run.
Okay, so after reading this (at work ) I tried something on the way home. I set the cruise control and made a mental note of the RPM on the tach. Then I engaged competetion mode. There was absolutely no change in RPM or speed by engaging or disengaging competition mode. Maybe this has nothing to do with your point, but it seemed like an imperical test of your concept at the time. Had the engine or vehicle speed changed when I changed modes, then that would tend to prove your theory that Competion mode effects engine performance or throttle position. But, there was no change, so...
...there you have it.
- for whatever that's worth...
Good point, but I think the car references vehicle speed not throttle position - so requiring more or less throttle on the drivers end wouldn't have any effect on this. Being a manual transmission there is no way that the RPM's would be able to change without the vehicle speed changing.
Maybe a better explanation is the throttle feels "squishy" in competitive mode, or is just overall less responsive to added throttle? I don't know how to explain it properly but there is a difference.
I will be hitting the dyno soon (hopefully, it all depends on when it quits snowing) and will make sure to test in both competitive and standard driving modes. Once again not saying that there is a power difference, but it would help with my curiosity...
Ranger
No matter the difference I feel in the car from every day driving and competitive mode - I certainly plan to have AH enabled when I race. It has saved my bacon more than once on the street, so I have no doubt it will serve me well on the track too...
No difference - just the active handling is gone in CM.
I had a guy tell me that the car handled differently in CM, i.e. it could go around corners better - he felt the difference in the shocks and spring rates he told me.
It's the new CM Placebo System - adds 10% to the SOTP HP number.
best regards -
mqqn
Too funny. A universal phenomenon in the car world. " I put a new air cleaner in, and it feels much faster"
I to have been playing with this. The other day I went into Comp mode and nailed it in second gear at around 40. No tire spin and only about 10 or 15' going into 3rd. Back into normal range and try again at around 40 mph, adding throttle where it starts coming into the cam and the tires start spinning and it catches itself, same thing going into 3rd hard spins like crazy and catches itself again? For some reason the car feels more powerful in normal mode? I don't think it is just me but who cares the car is way to much fun!
It "catches" itself because it's sensing you're loosing traction.
Either way, I never turn mine off. It gives me peace of mind and I hate it how the DIC is useless when in Comp. mode.
